Sponsored by: Innova
Help On Wiring
Old Jan 23, 2006 | 08:40 AM
litnrod's Avatar
litnrod
Default Help On Wiring
OK, guys, I need some wiring help.
I replaced the doors with JL Audio 5.25", and a set of 6.5" Components.
I couldnt believe it all fit.
Rear Speakers got swapped for 5.25" Components.
I added JL Audio 6x9's in the well areas on the left and right, and a 10" Soundstream sub in the middle.
I am using two amps, a kenwood 4-channel, and an xtant 3300x to run it all.
My problem: I used the GM02 wiring harness for the head unit and no power..ARGGGGGGHHHHH, the wiring harness is for 1988+ GM, and is listed for being used with the corvette...as well it fits the harness from the car.....
Has anyone else had this problem? I only need the power, ign, and ground, remote (but only from hu to amps) right? Based on the wiring harness, yellow is Constant, Red is ignition and Black is ground.
But the harness from the car does not match with these colors??? Please help....I spent the entire day yesterday frustrated.
HELP ME????!?!?!?!!?
Old Jan 23, 2006 | 09:11 AM
Tony2's Avatar
Tony2
Wire Function Colour
12V DC Battery - Orange
Ground - Black & black/white
Power Antenna - Dark green
Remote Turn On(output) - Dk.green
You should use a multi meter to test all of your wires beforehand to confirm.
Tony2
Old Jan 24, 2006 | 06:46 PM
markcz's Avatar
markcz
You can now find all of the stock radio plug schematics in post #9 of the C5 FAQ sticky thread.
Old Jan 24, 2006 | 06:59 PM
scott_fx's Avatar
scott_fx
I'm ashamed! i didn't even remember your post. i should read the c5 faq instead of bi@!#$ing at other to do it.
Old Jan 24, 2006 | 08:07 PM
markcz's Avatar
markcz
Don't feel too bad, I uploaded the plug pics last night, then they just got approved this afternoon, and I just updated my FAQ post to include them less than 30 minutes before your last post in this thread.
Old Jan 25, 2006 | 01:00 PM
litnrod's Avatar
litnrod
thank you gentlemen,
I picked up the acc from the a/c harness. the fifth wire from the left...a brown one. It works.
To Help On Wiring
