Effect of cover over subthump box?
Cruise-In VIII Veteran
Hi, all --
I'm planning on keeping my stock head unit, but replacing the speakers/Bose amps.
Rather than asking a generic "How do I do it?" question, I've been searching and gleaning info from hundreds (thousands?) of posts -- what a great resource! I'm also about 2/3 through a reference, "The Car Stereo Cookbook" (sort of an "audio for dummies" ).
That said, I have one question for which I haven't been able to find a definitive answer.
I have an '04 coupe, and was planning on a 10" sub in the subthump box in the center rear compartment. I *really* don't want to leave the sub exposed, both to prevent damage to the speaker, and to avoid putting the box on display for thieves (this is my daily driver, so she's out a lot).
The Question: What would be the effect of putting the factory center compartment cover back in place over the box?
The impression I have from my reading is that because bass below ~100Hz is felt more than heard, this should not be a major problem, particular since my "demands" aren't extreme -- I'm not into mega-thumping; mostly country (Reba McEntire), Rock (60's-80's), and some of Classical (Vivaldi, Strauss) (a bit eccletic, no? ) at moderately high volume.
So, thoughts? comments? futher suggestions?
Thanks!
Mark
Thanks!
Mark
I plan on doing the same thing with mine and it is also a daily driver. You will lose some bass output both in volume and most likely a bit in the musicality/accuracy areas due to the woofer having to "play through" the cover. You are effectively muffling the sound some. If you are not in to a lot of bass throw an extra 50-100 watts at the sub and you will never know the difference.
G'luck
Fej
G'luck
Fej
You will give up a ton in sound quality and volume, just tried it on my setup which is similar to what you want to do.
Remember that you are moving air to make sound, putting the cover over the sub reduces it's ability to move air.
Worst is that you lose the "Tone" of the sub, makes it a one note sub.
Just MHO.
Just MHO.
Hmm sounds like it might hurt worse than I thought What my plan was on mine was to keep the back 1/6th flip up open for stereo use to give it a very large "port" lol.
Will have to experiment some with mine when I get it going.
Fej
Fej
St. Jude Donor '06
just get a frc, you wont have to worry guys
it will be interesting what you guys come up with though as far as a cover. Only thing i would be able to think of is a fine black mesh to blend in with the carpet. But thats probably restrictive as well
St. Jude Donor '06
Originally Posted by scott_fx
you can get acoustically transparent speaker cloth and put that in front of a wire mesh (for stability) and have a pretty clean and hidden look.
1 Post
St. Jude Donor '06
Here is what I did on my cover so I wouldn't loose any sound quality and also keep a stealth look and protect my sub. I had some thin gauge aluminum floorplate left over from another project and used it for my cover. I used the factory cover as a pattern for the new cover. I covered it with some acoustically transparent black carpet that I picked up at a stereo shop. I took the factory latches out of the factory cover and put in the aluminum cover. Next project is to build a cover for my amp that will conceal it up to the heat sinks for more of a stealth look in the back. I am using a SubThump Stealth 12" box and an Image Dynamics IDQ 12D2 V.2 I am really impressed with this sub, great sound quality and it will rock if you want it to. I finally took the time to learn how to post pictures!!!
St. Jude Donor '06
great idea bfhawki
The problem i have is with the Z06. We dont have the factory latches in the center compartment. Only on the center cover. So there is no real way of keeping it covered and to stay put once the bass starts to hit. Mine just vibrates loose and the cover rattle like crazy. My center cover with the 1/4 of it that flips up has velcro and that doesnt hold in very well with the bass hitting either. Im in a FRC so i dont have to worry much about it other than when im storing stuff. Its you coupe guys that need to come up with something that i can copy
St. Jude Donor '06
Originally Posted by fej
DPG just do like I am going to and keep your golf clubs in the back I hope that works for me at least heh .. will know tonight.
Fej
Fej
Originally Posted by DPG
great idea bfhawki
