Sponsored by: Innova
Recommended sub for a 0.4 cu ft box?
Old Feb 11, 2006 | 11:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Recommended sub for a 0.4 cu ft box?
I built a box, it's only .42 cu ft, that's all the room there is for it.
Looking for a 10" sub to stick in there. How big a deal are the sealed box ratings on these subs? Most are > .65 cu ft, and there's a few rated below that.
Should I pay any attention to these numbers?
I'm looking for something mild <200rms that I can maybe drive with a 4+1 amp.
Old Feb 12, 2006 | 01:04 AM
unstressed's Avatar
unstressed
Loading it with poly fill will make the sub think the box is bigger. Don't sweat if you are not perfect.
Old Feb 12, 2006 | 10:06 AM
Darion's Avatar
Darion
Check out Image Dynamics.
http://www.imagedynamicsusa.com/page.php?page=products#
They have several 10's that will fit you box size and they make a very nice product. I have two 8 inch subs in my car and they handle plenty of power and sound great.
It is true that poly fill will make the woofer think the space is a bit bigger but your only looking at about 10%-20% at the most.
As far as staying in the manufactures specs I feel it is important. Yes the driver will work in a box that is smaller than recommended but it will not sound as good as it can. My experiance with a box that is too small, say .4 cu. ft. when spec is .65 cu. ft., is the woofer sounds a bit dead, it just doesn't have the space to work with that it needs.
Hope this helps and any other thoughts just post and I'm sure you will get the help you need.
Old Feb 12, 2006 | 01:01 PM
Homer3D's Avatar
Homer3D
Diamond Audio makes a 10 inch sub that works in the .34 sealed box.
http://www.diamondaudio.com
Boston Acoustics might make something that might work as well.
http://www.bostonacoustics.com
And of course Eclipse
http://www.eclipse-web.com
Old Feb 12, 2006 | 03:05 PM
CentralCoaster
All Diamond Audio's stuff is rated between .65 and 1.25 cu ft.
A few of the Boston's look good for small volumes, I've been impressed with boston stuff in the past.
I'll just call crutchfield and let them overcharge me in exchange for some helpful advice.
Old Feb 12, 2006 | 03:20 PM
scott_fx's Avatar
scott_fx
image dynamics makes a great sub, dont rule them out.
Old Feb 12, 2006 | 05:03 PM
CentralCoaster
Looks like Image Dynamics is the way to go...
So with a bridged 2-channel amp, I need a single voice coil sub or dual for 4 ohm?
Old Feb 12, 2006 | 05:09 PM
scott_fx's Avatar
scott_fx
i got mine from cardomain and they are on sale now; i think, they also have free shipping on subs.
Old Feb 12, 2006 | 06:10 PM
Darion's Avatar
Darion
What ohm load will your amp run at, 2ohm or 4 ohm? This will help to decide if you need a dual 4 ohm speaker or a dual 2 ohm speaker.
Old Feb 12, 2006 | 06:33 PM
CentralCoaster
I don't have an amp. But I'm looking at bridging 2 channels off a 4ch amp, and powering the front components off the rest.
So this'd leave me with a 2ohm output right?
Old Feb 12, 2006 | 09:12 PM
Darion's Avatar
Darion
Yep, in that case you would end up with the amp on those two channels running at two ohms. Just make sure that the amp you are getting is able to run at two ohms on those two channels, many are not rated to do so. If you end up needeing the amp to see 4 ohms you can wire a dual 2 ohm sub in series and the amp will see 4 ohms.
Old Feb 12, 2006 | 09:18 PM
CentralCoaster
I bought a dual-2 ohm sub.
I really have absolutely no idea what I'm doing.
So the amp will be 4 ohms to each of the front channels, and bridged 4 ohms to the sub.
Old Feb 12, 2006 | 09:21 PM
scott_fx's Avatar
scott_fx
that's the safest bet, you may not get the most power but you wont screw up and fry an amp either (probably hard to do anyways with all the protection they put into these things)
Old Feb 12, 2006 | 10:07 PM
fej's Avatar
fej
Can't go wrong with Image Dynamics .
Figured I would throw this link in even though it is a 12". Designed to work in enclosures down to .25 ft^3.
http://www.diymobileaudio.com/forum/...ead.php?t=1646
Fej
Old Feb 17, 2006 | 04:18 PM
comp's Avatar
comp
Old Feb 17, 2006 | 04:30 PM
DPG's Avatar
DPG
St. Jude Donor '06
i went with the dual 10" IDQ's. they hit hard and thats off a phoenix gold octane r 8.0:4 amp. Im very happy with them and just wanted to thank you guys on the forum here for recommending them
Old Feb 17, 2006 | 04:52 PM
CentralCoaster
Here's my setup so far:
Image Dynamics IDQ10, 250/500 watt
JBL GTO75.4 520 watts, 104rmsx4, 284rms bridged.
I'm getting a jigsaw tonight to cut the enclosure hole.
I'm very happy with the enclosure, I'll show some pics later.
Old Feb 17, 2006 | 05:37 PM
bogus's Avatar
bogus
I can't wait to hear this monster! It should be REAL tight.
To Recommended sub for a 0.4 cu ft box?
