The arc audio subs are produced, well we will call it in a "very similar fashion" to the Image Dynamics IDQ line which is a well respected and very accurate and musical sub.
Given your price point I know where I would spend my money
I've always loved Polk, extremely clean with a good amp.
Nice, it looks like $200 will give me some options.
Also, I wil likely upgrade my 6.5 door speakers this summer, with some MB Quart speakers if the rear sounds as good as I hope. I will then pull the carpet and sound deaden the entire car and I will do the inside of the doors at that time.
Too many projects right now, put a new clutch in @ 1 week ago , then a new rack and pinion yesterday too.
I have those in a sealed box in my Saabaru with only 70 watts each, they rock. Though mine are branded ARC Audio 8. (Same manufacturer, similar subs)
Nice. I couldn't be happier with mine. Most people that hear them can't believe they are "only" 8 inch. I'm running around 400 watts to a pair of them and they more than keep up with my CDT comp set and upstage set in front.
Image Dynamics 8v.3 subs. Less than $100 each. Great subs and even better for the price. I'd upgrade that Jensen amp to at least a PG octane like you are running for your comps.
For sure! The Jensen is a low end deal, I have had it laying around for a while.
I also have an old Eclipse 4x50 watt that I might be able to use in its place. This dude is OLD!
