Need a little help here!
-Jason
I don't know the exact specs to that amp but generally speaking for 4 channel amps they are designed to play "stereo" on channels 1/2 and bass on channels 3/4. Most 4 channel amps have much different crossover settings on channels 1/2 vs channels 3/4. Often times there are subsonic filters and bass boosts set up for channels 3/4 as well. No idea if you are using the crossovers on the amp at all or if this applies to this particular amp.
Reread your post and you should route rca's and power wire on opposite sides of the car if possible. I ran my power and rca's on the same side (passenger) but routed the RCA's taped up along the passenger side of the console and around the amp (mounted underneath passenger seat) to the connections and ran the power wire inside the carpet line edge and to a small fused connection and then to the amp. Closest the rca's come to power wire is at the amp about 6" apart and thus far I do not have any noise.
Fej
Fej
-Jason
can you try something for me.... put it back to 4 chan mode and switch the rca's at the amp... does the hum go to the other speakers?
I think part of your problem is that your deck is not sending the proper signal via your choice of rca outs to your amp. I think the problem is that when in 4 channel mode the amp is trying to use both sets of rca's and one of those sets is not sending a full range signal which is causing issues when coupled with the crossovers on the amp (IE the signal that is being sent is below the crossover frequency).
The sub rca's seem to be working fine and should stay on channels 3/4. You can mess around with the 0-18db bass boost features if you want but they tend to add a fair amount of distortion along with the boost. Keep your gains down if you are going to use it IMO.
I would do the following:
Reconnect your "good" set of RCA's to a different set of females on the HU. Start your HP filter for your front stage at around 100hz. Play your bass starting at around 80hz low pass. I am not sure of the rolloff on your amp crossovers but if it is 12db you may have to set the bass at a lower crossover point to keep it tight. Try and tune the system in pairs of speakers. IE midbass first, then connect the tweets and get it set up to a point of "loud as I am going to listen" without distortion. Use about 85% or so of the decks max volume and then SLOWLY bring your gains for your front components up to loud but "clear" (distortion free). Then add your bass and bring it in slowly at the rear gains until you get a nice blend that is not too overpowering. We are in a small car and you do not need a ton of gain to fill that cab with bass
The goal is to set it up as loud as you can without distortion and then you will not have to do a lot of messing around with it for various types of music. If your mids sound good at 100hz try sneaking them down until they start sounding "muddy" or what sounds to you like distortion ... the lower you can cross them generally the better your midbass is (toughest thing to do well in a car IMO).
Be sure to use a fadeable out for your RCA choice as it is likely that you will want some sort of option to fade the rear coaxials for your rear fill since they will be on HU power (and HU power is not very efficient nor clean and tends to get ugly around 70% of max volume)
PM me if you want to give me a call to help bro
Fej
-J
As for the other question I am thinking that you are referring to 0-35 on the headunit volume for the rears? I would personally disconnect those speakers in the rear for tuning purposes and then when you do connect them start at about +6 faded to the front ( I believe this should work with how you have it wired now) to keep full signal strength to the front components and send a guesstimate of about 60% strength to the rears regardless of volume number. IE at 27-28 volume ( I would tune for max around here .. most headunits start sending a clipped signal at around 85% of max) the rears should be seeing approximately 16 volume which should make for some decent rear fill. (cough hehe) If they are too quiet bring the fader more towards equal. Vice versa if they are still too loud.
Disclaimer I don't generally recommend using the fader to assist in tuning a system .. but in some circumstances when both amps and headunit power is being used it can be beneficial to overall sound.
G'luck
Fej
