Sponsored by: Innova
Where did you ground your amp (C4)
Old Mar 3, 2006 | 01:18 PM
VB Black Ice's Avatar
VB Black Ice
Default Where did you ground your amp (C4)
Well I'm in the process of doing a big upgrade and I want to relocate my ground. The original owner of the car grounded the amps to the seat rail which seems a little odd to me (not to mention the interesting rumbling of the bass tube when I get in and out of my seat). Where did you ground yours?
Old Mar 3, 2006 | 04:29 PM
vettenet's Avatar
vettenet
I removed the driver's seat, took off the bolt that holds the frame to the floor stud (closest to the tunnel), removed a bunch of the paint using a dremel and wire brush and grounded to that stud point. I've had no problems with noise, so I guess it worked okay.
Old Mar 5, 2006 | 03:44 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ran it through the firewall, just below the clutch m/c, actually on the side piece that the brake booster attaches to.
I don't think the seat studs are a good ground, they may not even conduct to the chassis & block very directly. Correct me if I'm wrong.
Good way to check would be for this guy to run his amp pretty hard and check for a voltage difference between the battery post and seat bolt.
Old Mar 5, 2006 | 08:24 PM
vettenet's Avatar
vettenet
I can try that, and probably will, but I'm pretty sure that this will turn out to be a reasonable ground point. I mean, the seat frames aren't bolted to a stud mounted to fiberglass...
When it gets a little warmer, I will test as you suggested, though.
Old Mar 6, 2006 | 12:39 AM
bogus's Avatar
bogus
I went back to the battery.
To Where did you ground your amp (C4)
