Sponsored by: Innova
Mounting tweeters. where?
Old Mar 5, 2006 | 11:25 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Mounting tweeters. where?
I am torn between the bottom of the a-pillar pointing up towards the windshield or the door pulls. i think the a-pillar would be easier. doesn anyone have any how-tos with pics of how to mount the tweeters in the door pulls?
Old Mar 5, 2006 | 11:48 PM
bogus's Avatar
bogus
if you do the windshield install, don't forget to reverse the speaker wires (+ to -) so the reflected sound will come back at you correctly.
I think the door pull would be better for off-axis performance.
what kinda drivers?
Old Mar 5, 2006 | 11:57 PM
DanielW's Avatar
DanielW
They are CDT CL-61A Components. I built a custom door mount for the speakers, and mounted the tweeters above them, but the way i positioned them, i think the door skin is blocking them. So the door mount is a better idea you say???? Would you happen to know of a guide with pictures of how to mount them in there?
Old Mar 6, 2006 | 12:38 AM
bogus's Avatar
bogus
you would have to cut a hole into the door... I know folks have done it here, but it would require a search to get the answer.
try "C5 tweeter installation" or something of that nature.
Old Mar 6, 2006 | 08:02 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
I put mine in the door pulls. The CDT's actually swivel a litle in the cups so I could point them a bit forward.
The tweeters were really easy to mount in the door pulls, all you need is a drill bit the same size as your tweeter and a dremel to trim off a bit of plastic on the back side.
I had my pillar off to run my V1 and what I remember there isn't much room between the two!
Old Mar 6, 2006 | 05:13 PM
DanielW's Avatar
DanielW
Thanks for the pics.
Old Mar 6, 2006 | 05:57 PM
Darion's Avatar
Darion
I have tweeters in my door pulls and stage fronts in my pillars, there is room at the bottom of the pillar. Mounting in the pillar was not a problem, I would say easier than in the door pull for me.
Darion
Old Mar 27, 2006 | 01:25 PM
PJSALERNO's Avatar
PJSALERNO
Any pics on the door pillar install? Thanks
To Mounting tweeters. where?
