Sponsored by: Innova
Help... antenna on 94 coupe
Old Apr 7, 2006 | 10:39 AM
charliebean's Avatar
charliebean
4th Gear
Default Help... antenna on 94 coupe
I'm replacing the Bose stereo in my 1994 coupe. how do I connect the antenna to the new head unit?
Old Apr 7, 2006 | 12:59 PM
adown's Avatar
adown
If it doesn't have a power antenna wire connect it to the amp turn on wire. It should be blue. However, this wire is lower voltage, but should work. If not use this wire to trigger a bosch style relay from radio shack.
