yet another C5 stereo upgrade plan...
to keep things simple I'm sticking with brands I've known and liked for the past 4 years in my truck......yet also seem to be liked here as well.
we're fitting all this in a 03 Z06 that probably will see a rollbar, I don't want a partition and I dont' need crazy bass, but I need a sub...
head unit - alpine iva w200....I've seen a double dins done in C5's with minor trimming....didn't forsee any problems until i read only 2v preouts...
amp - kicker zx 700.5 (85x4 and 425ish at 4 ohms on a sub) was thinking of 4 speakers and a sub, so was thinking 5 channel. Then it seems most people say in teh tight confines of a vette go with a good stage adn a sub....so I'm open to suggestions
front speakers - focal polykevlar 165 kf's 2 way (older model but love the sound the kps is an updated one.....now I'm thinking maybe 3 way?)
rear speakers - well I think I'm gonna cut these outta the mix.
sub jl 10w6 - I want a small box in the rear center well.....(I have a kicker L7 square in my truck, hits like a monster but its got a nasty flatspot the midranges just can't keep up with above 100 hz..)
most of all I want simple and loud but sq not spl boombastic I've done enough of that crap in the past.
give me some thoughts guys..
Rest of the gear looks pretty solid, the 2v outs hurt a bit, you could go external crossover, JL clean sweep etc to boost your signal to your amp if you felt that you needed to. At the end of the day, the less gain you have to run on your amp the less distortion you will generally encounter. A higher voltage signal gives a stronger signal for the amp to amplify, therefore creating the same or more volume with less gain/work from the amp. Generally results in cleaner sound.
Fej
(let me know if you want to purchase mine off of me)
and i agree with fej
those vrumvrum plates.....those would take the midbass and midrange and then I just have to mount a tweeter? and I could run serious power that way....say 85 a piece to the midbasses...then 85 to the tweet and midrange adn then drop a 10 in the center cargo area?
I love the damn kickers in my truck, they run ice cold under the entire rear seat linked up end to end.....with little to no ventilation...and clear and clean as hell...barely cranked up at all
was thinkin of just dropping the vette at a shop but talking to a few of them.....I know I'm doing it myself again, lol.
You would need a headunit with a 3 way crossover built in, plus some passive crossovers of some sort to make it all work. Or you could just get a external processor/crossover of some sort to handle most of it. PM me if you want to chat about system make up/set up
Fej
