Sponsored by: Innova
Best 3 way drivers for SQ
Old Apr 24, 2006 | 08:36 PM
simpleman68's Avatar
simpleman68
Originally Posted by kumar75150
If you are looking to spend that much on speakers, Id suggest looking into Brax amps. Those fawkers are so clean.
Dayyyyum! I've heard of these, I guess I should check one out sometime.
Scott
Brax X 2400.2
Cont. power rating at 4 Ohm p. channel: 4 x 135 Watt
Cont. power bridged into a 4 Ohm load: 2 x 470 Watt
Total harmonic distortion (THD): < 0,001%
Signal to noise ratio: > 110 dB
Dampings factor at 4 Ohm: > 400 A little sub-par
Frequency range 20 Hz -20 kHz:
TIM Distortion: < 0,009%
Input sensitivity: 300 mV - 7,5 V
External Fuse: 100 A
Input impedance: 10 kOhm
Dimensions (H x W x D) in mm: 53 x 238 x 473
Weight netto: 8,2 kg
fitted with High-End Burr Brown ICs for the best sound performance
solid stainless steel name plate with individual lasered serial number
exclusive heatsink design with platinum color or chrome finish
transistor selektion in 300 categories, therefore very low tolerances
Old Apr 28, 2006 | 01:10 PM
bogus's Avatar
bogus
www.tubedriver.com
