Sponsored by: Innova
C4 Tweeter Placement?
Old May 4, 2006 | 01:54 PM
RFDrpm's Avatar
RFDrpm
Default C4 Tweeter Placement?
Where are you guys mounting your front tweeters?
I saw a sick install in a C5 where he put them behind the door handle. I dont think this is going to be possible in the C4 though...
Old May 4, 2006 | 10:48 PM
VB Black Ice's Avatar
VB Black Ice
I hid mine behind the rear-view mirror
Old May 4, 2006 | 11:00 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Do you have pictures of that. I would like to see how you did it.
Randy
Old May 5, 2006 | 12:24 AM
bogus's Avatar
bogus
I stuck mine into the upper part of the door panel.
Old May 5, 2006 | 09:44 AM
adown's Avatar
adown
I put mine in the flat plastic piece by the door handle. Flat/swivel mount. Looks factory if your not a Vette nut.
Old May 6, 2006 | 11:45 PM
RFDrpm's Avatar
RFDrpm
Bogus,
Upper door panel? Where? there doesnt seem to be ant good place there. Got a pic.
VB Black Ice,
I too would love to see how you did that...
Old May 7, 2006 | 02:09 AM
bogus's Avatar
bogus
a classic thread:
http://forums.corvetteforum.com/showthread.php?t=955497
Old May 7, 2006 | 04:00 PM
VB Black Ice
I'd give you a pic but I don't have a digital cam ready ...
Old May 7, 2006 | 07:58 PM
RFDrpm's Avatar
RFDrpm
Ok Andy,
So Ill ship my door panels next week, when do you think you can have them back by?
Old May 8, 2006 | 12:00 AM
bogus's Avatar
bogus
to be honest, to build the door panels isn't that hard.
They easily come apart.
1) remove the door panel.
2) remove the carpeted piece.
3) remove the carpet.
4) drill a big hole kinda where the speaker will go.
5) get a piece of MDF or particle board, and cut it into a ring that will fit the speaker. I don't think more than a 4" will fit there.
6) Get a piece of cardboard and cut it into a 3" strip, long enough to wrap around the ring. Staple it to the ring and coat in a layer of fiberglass resin. That will give it strength (to be honest #5 and #6 could be done first).
7) hot glue the dried ring assembly to what used to be carpeted with the big hole. It might require some minor tweeking to fit it, and be sure it's vertical to the door - all the angles can confuse things.
8) Once that is done, get some bondo and layer it around to give some bevel and smooth out the angles. Sand accordingly. I have since redone my driver side (haven't had time to hit the passengers side) with black vinyl, using 3M Spray on Contact Cement.
That's it... it just takes time for everything to dry.... the fibreglass resin is the longest - 24 hours. The bondo? about 20 minutes per coat, and the hot glue, just a few minutes.
To C4 Tweeter Placement?
