Sponsored by: Innova
Speed sensor wire location
Old May 10, 2006 | 02:07 PM
Fast one's Avatar
Fast one
Default Speed sensor wire location
Where is the speed sensor wire to feed a navigation unit?
Old May 10, 2006 | 03:52 PM
DPG's Avatar
DPG
St. Jude Donor '06
ttt
Old May 10, 2006 | 04:40 PM
pk1's Avatar
pk1
from the audio FAQ
I have a navigation h/u that has to connect to a speed sensor wire, where is it?
You will have to tap into the harness on the instrument cluster. You need to find the Green/white (A7-circuit 817) with a tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
Old May 12, 2006 | 01:31 PM
Fast one's Avatar
Fast one
Thanks, the dash is off now so the instrument cluster is easy to get to.
To Speed sensor wire location
