Sponsored by: Innova
C4 read ground
Old May 17, 2006 | 01:04 PM
Larry64's Avatar
Larry64
Default C4 read ground
What is a good place to pick up a ground in the rear of a C4 for an amp?
Old May 17, 2006 | 01:45 PM
Larry64's Avatar
Larry64
Default rear not read, sorry.
Working on the car and running into the house to type, I'm no clerk.
Old May 17, 2006 | 01:56 PM
DPG's Avatar
DPG
St. Jude Donor '06
not sure, but im sure a test with a multimeter can help you out. I used the seatbelt bolts in my c5 though
Old May 17, 2006 | 02:13 PM
RFDrpm's Avatar
RFDrpm
I use the rear seat bolts, Slide the seat forward and you can easily reach them.
On my '92 I even routed it under the carpet via a hole in the forward bulkhead of the storage compartment.
Old May 17, 2006 | 04:13 PM
bogus's Avatar
bogus
I ran up to the battery.
Old May 17, 2006 | 07:10 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I heard that that was not a good thing to do. Something about picking up interferance from the engine?
Old May 17, 2006 | 07:23 PM
BarryK's Avatar
BarryK
not so, the battery is an excellent place to ground at - actually it's almost always the best.
The battery most of the time even acts kinda of like a filter and will help eliminate interferrence problems and noises you can pick up from other parts of the car.
When designing very complex systems most of the time we ran all grounds to a single junction than ran the junction directly to the battery for ground.
Just make sure you use a large enough ground cable for the run length. We always ran the same size ground cable as our main power cable.
Old May 17, 2006 | 08:02 PM
scott_fx's Avatar
scott_fx
yeah...i never understood why they say ground within 9" of the amp. i't going to end up at the battery ground at some point, why not give it a direct shot
Old May 17, 2006 | 09:39 PM
BarryK's Avatar
BarryK
in GENERAL, a short ground line from the component works fine but as we all know a Vette is a bit different from other cars and a good ground point is much more difficult to find.
On the most basic install a ground near the component is usually ok but it always allows for the risk of a ground loop problem.
I've done single amp systems and I've done multiple amp system with 8 or 10 amps and whenever I've designed the wiring to run directly to the battery we've never had a problem with noise or ground loops.
It's MUCH easier to do it right the first time than get everything wired up and than have to start tracing down noise problems afterwards, especially if it's a very custom install that may take a full two days disassembly just to get to the wiring!
Believe me, when you are doing a system that cost the customer $10k to $60k (that was prices from 10 years ago!) you do NOT want them returning with noise issues you now need to try and find and fix, you want it right the first time around.
going directly to the battery helps greatly in this.
We also troubleshooted many systems not done by us with noise problems. Want to guess how we solved them in most cases........
Old May 18, 2006 | 01:30 AM
bogus's Avatar
bogus
I have been running my system straight to the battery for 5 years now, ZERO noise... even at night, with the AC, wipers and lights. Nada.
Old May 18, 2006 | 05:18 PM
Mtrhd329's Avatar
Mtrhd329
I ran my ground to the mounting bolt for the rear hatch popper bracket. Take off the rear trim and it is the little popper to pop the rear glass up. There is a bolt right below it that is .03 ohms to ground and it seems to be working fine for me.
To C4 read ground
