Sponsored by: Innova
any easy way to do this.....
Old May 23, 2006 | 10:35 AM
DPG's Avatar
DPG
St. Jude Donor '06
Default any easy way to do this.....
Is there an easy way to make a template for the door speaker mounts other than taking paper and tracing it and then transfering it to mdf or whatever the material is. I just want to make sure I get all the holes lined up right. Any template out there that are already made? Thanks
Dave
if any mods come visit, please delete the other 3 dup threads that i started by accident. It wasn't going through right
Old May 24, 2006 | 11:31 AM
Eros's Avatar
Eros
Take out your factory speaker, turn it over on a piece of PVC board, go around it with a pen, put your pen where the holes are, get a saw, and cut out the "rim", get a drill and make your wholes, also draw the opening in the middle for your replacement speaker by size, and Voila....you're done.
Old May 24, 2006 | 11:53 AM
DPG's Avatar
DPG
St. Jude Donor '06
thanks eros. I tried it that way and just felt that it wasnt accurate enough. I have come up with a diff way that seemed to do the trick for me. Thanks
Old May 24, 2006 | 04:44 PM
scott_fx's Avatar
scott_fx
i've never heard about using pvc board, why did you suggest that?
To any easy way to do this.....
