Sponsored by: Innova
what components fit in a c6 door?
Old May 23, 2006 | 10:42 AM
97C5's Avatar
97C5
Default what components fit in a c6 door?
What will fit in these doors?
I'd like to do a 3 way system with mid-bass in lower, mid near doorhandle, and tweeter in a-pillar. My feeling is that this would have the highest sound stage. I'm just not sure what will fit in these locations. I know I should take the door apart to find out, but how much room is available in the mid-mount location?
If 3 way not doable, I will concede a 2 way component set.
Looking at several entries from the Focal line... 180w (will a 7" fit?), 165w (6.5"), 165k2p, and 165v3.
Any suggestions for a speaker arrangement?
Old May 23, 2006 | 02:40 PM
kirbyloid's Avatar
kirbyloid
Default speakers
I am looking at some 9inch PG that were made by Morel where Bose subs are and some alpine type x by handle and tweets in A pillar
Old Jul 17, 2006 | 11:49 AM
kirbyloid's Avatar
kirbyloid
Default compnents
Ended up installing JS Audio XR 3 way comonents and an amp in rear cubby. Plan to add custom fiberglass stealthbox to rear similar to JL stealth but custom made for Convertible.
BTW- had rears rewired for stereo and put JL two ways in the rear and eliminated center.
Old Jul 17, 2006 | 12:03 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I'm also looking at the Focal 165K 3 ways. With the way the Bose are mounted you have a 10" opening at the bottom but the mid is actually mounted to the door panel. Here's a couple of pics to give you the idea:
My plan is to put the tweet & midbass in the 10" opening and the midrange in the door panel.
Old Jul 17, 2006 | 01:07 PM
kirbyloid's Avatar
kirbyloid
Default components
I put the lower and mid in the 10inch opening and tweet in door
Old Jul 17, 2006 | 03:51 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
That would certainly be ideal from an imaging standpoint, but unfortunately not physically possible with the speakers I'm considering.
To answer 97C5's question more specifically... any of those Focal setups would work in the opening. For the 180W you'd put the 7" in the sub opening and the tweet where the mid is, same would make sense for the 165 2 way. For the 165 3 ways you'd have to pair the tweet down below and put the mid in the door. Any way you do it you'll have to make some sort of mounting frame.
Old Jul 17, 2006 | 04:23 PM
kirbyloid's Avatar
kirbyloid
I used th XR JL Audio 3 ways and made plates as well as plated the door opening where the piece of rubber is to basically enclose door, also used the rear plate as mounting location for the crossover
Old Jul 17, 2006 | 09:04 PM
stinky's Avatar
stinky
Komoman, if you've still got the door off could you measure the depth/height of the 3 1/2" speaker and the magnet's diameter. Thanks
Old Jul 17, 2006 | 09:31 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Sorry, I don't still have the panel off. I did measure the depth of the driver from the back of the plate, it's 1.75" deep. The pocket in the door where the magnet goes is 1.125" deep. I didn't remove the mid so I can't tell you what the actually depth is, as it's obviously not the sum of those 2 numbers, but I would guess it's in the 2.25"-2.5" range. I didn't measure the diameter.
Old Jul 18, 2006 | 01:22 AM
stinky's Avatar
stinky
Thanks man.
Old Jul 18, 2006 | 02:06 PM
97C5's Avatar
97C5
How do you plan to fit the 165s? That's two 6.5" speakers in each door...
Old Aug 2, 2006 | 04:39 AM
ydlee24's Avatar
ydlee24
In my C6 I have 2 4" MB Quarts Coaxial in door panels with X-overs and in the rears JL Audio 5.25" XR Coaxials with X-overs and in the doors 8" kicker SSMB subs all ran from a JL Audio ES4500 6-channel amp. On the stock amp I have running a 3.5 MB Quart Coaxial for the center dash. Stock HU with PAC GM24.
Old Aug 3, 2006 | 09:42 PM
MannyS's Avatar
MannyS
Were the 4" MB Quart an easy fit in the door panel?
Old Aug 4, 2006 | 11:46 PM
Moto's Avatar
Moto
Yep
Old Sep 15, 2006 | 06:42 AM
mkiv808's Avatar
mkiv808
That's a pretty nice setup. Very close to what I was thinking of doing. The 4" MB's screw into the stock location without modification?
Was the 8" Kickers the only woofers you could find with the right mounting depth?
How does it sound?
Old Sep 15, 2006 | 10:30 AM
leolufse's Avatar
leolufse
I went with DLS Iridum 8.2 components. 8" treated paper woofers and 2" silk dome tweets. http://www.dls.se/english/speakers/Iridium82i.htm
They make a 3 way set as well. Very natual and smooth with excellent midbass. I completed the system with a 3.5" Boston center channel and a 10" Image Dynamics sub in a JL box. All run from a PPI 1000.4 amp. Some pics of the install:
http://peachstateposse.com/Gallery2/album178
Old Sep 15, 2006 | 04:54 PM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
To what components fit in a c6 door?
Old Sep 15, 2006 | 05:15 PM
ydlee24's Avatar
ydlee24
How does it sound?
With the 4" mb quarts I used a adapter to make the 4" fit on the 3.5" location. The kicker mounting depth is about 2 1/4", I believe you have about an 3" before hitting the glass.
I have the 8" mid bass set at high pass setting because on low pass on high volume the 8's distort since there is not no enclosure even though they are free air, free air subs to have a limit of capabilities.
It seems the 4" mb quarts handle well with the rear 5.25 JL's but I still want it a bit more sensitivity coming from the front so I think I plan on changing the 8" mid range and get 6 1/2 coaxials so I can have an extra tweeter.
Old Sep 16, 2006 | 06:25 AM
mkiv808's Avatar
mkiv808
Where do you buy those speakers?
Old Sep 16, 2006 | 07:38 PM
MAGRED2001VETTE's Avatar
MAGRED2001VETTE
LOL....get ready for a second house note! Lets just say more than a montly vette payment w/ nothing down !
