Sponsored by: Innova
Factory bose amp question??
Old May 26, 2006 | 02:05 PM
EB-Z06's Avatar
EB-Z06
Default Factory bose amp question??
I was reading through some of the sticky post and found this..
"The bose interface will give you pre-amp level outputs that you can run to the rca jacks of your amplifier."
Is this true? I can just used the factory bose amp to run the RCAs to my amp instead of buying an line output converter to splice into some of the wires? If so, where is the factory amp located?
I'm not doing a huge audio install or anything. Just simple amp and sub.
Thanks!
Old May 26, 2006 | 02:17 PM
scott_fx's Avatar
scott_fx
you misunderstood. the bose interface is a unit that interfaces with the bose system. sorta like a glorified line output converter.
Old May 26, 2006 | 02:22 PM
EB-Z06's Avatar
EB-Z06
Ah, ok.. Makes sense! Thanks!
To Factory bose amp question??
