For 2 years it had almost undetectable noise from the altenator and blower motor, but in the last year these noises have slowly increased and are now audible.
Can I fit Toroids or balances to the wires and if so which wire(s) need shielding and what should I use?
I basically know nothing about removing the noise, except on old cars a capacitor could be put across the generator's terminals, so I've come here to the fount of Audio knowledge.
S'nut
Try wrapping all speaker wires round a ferrite toroid...That should suppress the noise.
since it wasnt there before; personally i'd try to figure out what changed to warrant the new noise. If the noise steadily increased I'd first assume that it's corrosion of the grounds. Maybe check there before you go on to the band-aid fixes
Thanks me ol mate smacko - will the Toroid guarantee to clean up the sound? do i need it on ALL the leads power and signal?
scot_fx - thanks also, the amp gets power direct from the battery, headunit from the old Bose leads - I'll check all the grounds.
I was wondering if it's power leads or signal leads between CD and Amp or speaker leads ?
S'nut
Yeah I reckon so mate; you were right on the money - (And forgive me if my electronics days are but a shadow of a memory), BUT; yes - wind as many wraps of speaker wire (And you'll either need a BIG bead or less turns) around the toroid as you can. I don't think you'll need to do it to pwr leads tho; just the speaker wires as this should effect an RF choke.
In the shadowy depths of my memory, I also recall something as simple as a (really straining now!) 1000pf capacitor, screwed onto metal firewall (and herein lays the challenge on a corvette!) and the lead to earth, should also help attenuate the RF.
BUT; you prob want to check my memory out elsewhere (like a car audio forum) as I'm only going by vague memories here now mate.
PS; I already assume you're using quite heavilly shielded wiring.
I am thinking ground also. From all the times I have done a system, whine noise from the alt. are usually grounds. More over, its possible that the ground you have is not enough for what your running. I bought a ground block for my last system and then grounded it to the body. With a vette, you may just have to ground it to the frame. Good luck
there was someone on the forum a few weeks back asking about this type of solution. i think they sold it through ecklers or someplace like that. i believe it was c4 specific
That noise is usually from poorly shielded wires having signals "share" through electromagnetic coupling: Heres a couple cheap fixes I have used in the past:
Move the ground point somewhere else and clean the chassis to bare metal
Take two feet of the speaking wire wrap it into loops and attach a ferrous coil to bundle them all together closer to the speaker.(Creates inductance)
1/2w 1/4ohm resistor bridged across the leads(the values will vary depending on wire impedence though)
Decoupling caps across the speaker terminals.
Last I checked: walmat sold an expensive "hum remover" under the Scosche monkier for $8, its basically the above resistor and decoupling caps in a convenient package. I just have a hard time spending $8 for 15 cents worth of discrete components.
...Take two feet of the speaking wire wrap it into loops and attach a ferrous coil to bundle them all together closer to the speaker.(Creates inductance)...
...Add a few more components and you get a bonus crystal radio set for free!
