Sponsored by: Innova
Parrot 3200 "fuzzy"
Old Jun 10, 2006 | 11:30 PM
quiznos's Avatar
quiznos
Default Parrot 3200 "fuzzy"
Followed Steve's instructions for the Parrot Blue tooth - Works great - until I plug in the harness to the amp - The stereo plays fine - When I activate a command on the Parrot that sends a voice through it turns off the amp with the relay - perfect - but....the voice comes through very low and fuzzy? any ideas??
Old Jun 12, 2006 | 02:52 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
If I understand how that system you hook it to the speaker lines and mute the amp and then the Parrot box's amps drive the speaker. Which speakers do you have it connected to? If you have it hooked up to the rear speakers it might come through that way. Not sure what Steve's how-to uses, but to me the 3.5" drivers in the doors and dash would make the most sense to use.
Old Jun 13, 2006 | 08:11 AM
TMagnum's Avatar
TMagnum
1st Gear
Hi from Germany,
do you know how to do the job on a C5? I have the wiring plan, but i dont understand the soundprocessor? Do they call the amps processor?
Thx 4 your help
mag
Old Jun 17, 2006 | 12:30 PM
quiznos's Avatar
quiznos
The Parrot is hooked up to the front drivers (Out from the amp not low level in) I tried everything to fix the distortion - I ended up hooking up the relay to the main negative line going to the amp - When the parrot outputs on the mute line it cuts power to the amp completely - Everything works great now - I have the NAV with Onstar - that may have been the issue?
Old Jun 17, 2006 | 12:31 PM
quiznos's Avatar
quiznos
I would imagine that they mean the head unit by psound processor?
To Parrot 3200 "fuzzy"
