Sponsored by: Innova
Changed fuse and stero wont work
Old Aug 28, 2001 | 11:29 PM
Kehrer923's Avatar
Kehrer923
Default Changed fuse and stero wont work
I change my fuse holder because my old plastice case broke and now the stero wont play music like the receiver work , but my amps must not be gettign any power. I put a bigger fuse in could that be the peoblem?
Old Aug 29, 2001 | 12:21 AM
Dave84/76's Avatar
Dave84/76
Default Re: Changed fuse and stero wont work (Kehrer923)
Check power before the fuse and after the fuse. If you have power before but not after, then either the fuse is no good, or you have a bad connection in the fuse holder.
Old Aug 29, 2001 | 03:51 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Changed fuse and stero wont work (Dave84/76)
Ow my eyes. Check your spell check also. :crazy:
Anyway, check the power before and after the fuse. If you have power, check the remote line and then the ground. Make sure your fuse is in the engine compartment and not next to the amp because if your wire gets cut for some reason like an accident, the wire will be live if the fuse isn't in the engine compartment and it could start a fire, weld itself to the frame, etc.
92TripleBlack
To Changed fuse and stero wont work
