Sponsored by: Innova
CD changer problems
Old Jun 23, 2006 | 06:39 PM
AbsolutHank's Avatar
AbsolutHank
Default CD changer problems
I've searched this topic to no avail. The changer will eject the cartridge and accept it back in. At this point, it just sounds like its trying to load the CD (continous clicking noise). Up front on the head unit, it just shows ERR on the display after I try selecting the changer. Any ideas? I just bought the car and supposedly "everything worked." The car is a 98 coupe...thanks for any help guys
Old Jun 26, 2006 | 12:49 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
If you can eject the cartridge with no problem, try checking to make sure that the magazine sleeves are mounted in the magazine correctly, and also make sure there is nothing inside the changer, and that you are mounting the disc in the sleeves the proper way up.
If you still can't fix the problem with the checks, you may have a bad changer. That is not cheap...
Hope this helps!
