Sponsored by: Innova
C5 Subwoofer amp wiring??
Old Jul 9, 2006 | 02:16 PM
zberger's Avatar
zberger
Default C5 Subwoofer amp wiring??
I am doing an installation in a 2003 Corvette Z06.
We are using a Line Out Converter at the current time, and I cannot locate suitable wiring to get a good signal for the amp to actually produce some sound to my subwoofer.
Right now it would really be helpful if i could find some instructions on how to wire the system up with a line out converter.
Any help would be mucho appreciated.
Old Jul 9, 2006 | 08:07 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Tap the rear speaker leads behind the factory headunit should work but you must go to the headunit. Let me know if this helps or if you need colors or what. There are plug and play adapter that do this quite well
Old Jul 10, 2006 | 12:52 AM
zberger's Avatar
zberger
Did that already behind the head unit.. used the tan/grey and lt green and green wires
this nets me very little action from the woofer.
Old Jul 10, 2006 | 07:09 AM
adown's Avatar
adown
Did you use the bare wire for common? I have not done this yet, but C5 audio faq has a bose wiring help near the top that says to use the bare wire for common instead of the common or - in the schematics. Let us know how it goes as I too will doing this. Did you by chance read the Bose wiring tips by 99HT in the C5 faq? Thats what I was going to go by. Let us know if it does or doesn't work. Thanks
Old Jul 10, 2006 | 10:15 AM
zberger's Avatar
zberger
That was like 3 pages of reading.. I'd prefer just to have someone say here are the wires and these are the colors, put your t-taps here.
I read it a few times and didn't really understand it.
Yes, I used the bare wire for the common.
Old Jul 10, 2006 | 10:37 AM
DPG's Avatar
DPG
St. Jude Donor '06
ive heard that tapping into the wires isnt a clean enough signal and that its easier and you are better off using something like a pac adapter
Old Jul 10, 2006 | 10:46 AM
DPG's Avatar
DPG
St. Jude Donor '06
http://forums.corvetteforum.com/show....php?t=1439927
Old Jul 15, 2006 | 01:32 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Sounds like you are doing the wiring right, but you should probably have a Line Ouput Converter that is adjustable, and is made for factory amplified setups. Typically the signal generated by the wires behind the radio in vettes is a low level signal sent to the amps. A higher level signal for a standard LOC would be at the rear speakers themselves. The signal is already amplified at that point. Or get an adjustable LOC to compensate for the lower signal behind the radio.
Hope this helps!!
Old Jul 15, 2006 | 10:31 AM
Vette-Dream's Avatar
Vette-Dream
Originally Posted by NCR Dave
...A higher level signal for a standard LOC would be at the rear speakers themselves. The signal is already amplified at that point...
I'm sure the signal going to the rear speakers has the highs/lows already filtered out. At least when I tied into it to use as speaker level input for my sub amp the signal was horrible. No lows, some mids, definitely not useable for a sub amp. Hopefully this will save someone else the time of tapping into the rear speakers.
I ordered the PAC unit from a 20,000+ eBay seller. Unfortunately his account was cancelled shortly after my order, so I'm having to purchase this kit twice
I'm pretty sure I've read that others have successfully tapped into the door speakers, as these are subwoofers.
To C5 Subwoofer amp wiring??
