Sponsored by: Innova
Help Installing Pioneer CD Changer ?
Old Jul 22, 2006 | 09:18 AM
Button's Avatar
Button
Default Help Installing Pioneer CD Changer ?
I know nothing about doing this and need help.. The local shop wants $100.00 to do this!! I bought the almost top of the line unit from another Forum member.. 1. Can I hook up to the CD harness in the trunk? 2. How hard and how do you hook-up behing the Radio.. All the wires are marked .. I am really weak in the Audio Area but can mount the unit and route the wire with no problem at all. Thanks in advance to anyone that can help me save a lot.....
Old Jul 23, 2006 | 08:26 PM
scott_fx's Avatar
scott_fx
what year is your car?
Old Jul 24, 2006 | 04:35 PM
Button's Avatar
Button
Default CD Changer............
2000 with Bose system ... Thanks for the reply......
Old Jul 24, 2006 | 05:12 PM
scott_fx's Avatar
scott_fx
hmm..not sure if you can hook that up to a stock bose system. at the very least you'd need an adapter/interface and i'm not sure if they even make them for the pioneer decks. maybe pentavolvo can chime in.
here is a link to a tech tip about adding a kenwood cd changer to the system, the procedure should be the same:
https://www.corvetteforum.com/techti...=224&TopicID=1
again..this is all dependant on the interface
as far as getting ot the back of the radio, it's pretty simple. for instructions on how to get to the radio go on vette essentials' website and they have a console removal 'how-to'
edit...just plain losing my mind
Old Jul 25, 2006 | 03:38 PM
knewblewkorvette's Avatar
knewblewkorvette
I'm hoping I'm not misunderstanding you question.
Even though the Corvette factory's CD changer is a Pioneer, all aftermarket Pioneer CD changers will not work with the Bose HU. If there is an adaptor, I don't know about it. If you plan on using an FM-modulator then she'll work but I' against this approach since you will only get 50-15000 Hz and it will weaken you radio reception.
To Help Installing Pioneer CD Changer ?
