Sponsored by: Innova
Better XM Reception
Old Jul 27, 2006 | 05:19 PM
kirk78h's Avatar
kirk78h
Default Better XM Reception
I love satellite radio when it works. The problem is -- my daily commute takes me through some terrain where the signal cuts in and out. This happens mainly on heavily tree-lined roads and when I'm under power lines. I've tried moving my antenna around, from the wheel wells to behind the tail lights to the front dash, etc., without improvement.
Having said that, I was wondering if a different antenna would help. Specifically, I looked up the Terk marine antenna for satellite radios. I wouldn't want to put this on most cars, but it could be hidden easily in the vette. According to the specs at Crutchfield.com, the marine antenna has a 30dB gain while the regular car antenna has a 2dB gain. Is this the meaningful number I should be concerned with? Is there any reason this would not work? Any help or comments would be greatly appreciated (before I spend the $99......)
Kirk
Old Jul 27, 2006 | 07:20 PM
scott_fx's Avatar
scott_fx
try putting a metal plate under the antenna first. see if that helps.
Kirk
Old Jul 28, 2006 | 12:34 PM
LV_2_XLR8's Avatar
LV_2_XLR8
I love satellite radio when it works. The problem is -- my daily commute takes me through some terrain where the signal cuts in and out. This happens mainly on heavily tree-lined roads and when I'm under power lines. I've tried moving my antenna around, from the wheel wells to behind the tail lights to the front dash, etc., without improvement. Kirk
I got tired of the same thing, so I bit the bullet and mounted it on the halo. It doesn't look that bad compared to service I'm paying for, but not getting.
I don't know about the Marine antenna. That's an awful big difference in gain.
Old Jul 28, 2006 | 01:06 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Not sure if the gain will help in your situation or not. It's a line-of-sight issue, not a terrestrial broadcast reception issue(other than the terrestrial broadcasts in cities XM does for gap coverage). Having the antenna at the top of the vehicle definitely helps as the car itself won't block it's "view" of the bird. My brother & I both have SkyFi's with the same antenna, his is sitting on top of his SUV, mine is buried under the rear shelf cover of my sedan. He gets slightly better reception than I do, but not enough to make me move my antenna.
The metal plate idea could help as it would create additional antenna surface via the magnetic link.
To Better XM Reception
