Sponsored by: Innova
replacing breadbox
Old Jul 28, 2006 | 09:25 PM
Jim D's Avatar
Jim D
Default replacing breadbox
Has anyone replaced the breadbox, on a C4, with a dvd screen. If so pics please,thanks Jim.
Old Jul 29, 2006 | 01:32 AM
bogus's Avatar
bogus
I am sure it can be done.
thinking off the top of my head, I would start with some 1/4" thick MDF, then cut into a space for the monitor.
coat the MDF in fibreglass resin to give it some strength, then upolster it with something nice.
Old Jul 29, 2006 | 08:46 AM
Jim D's Avatar
Jim D
Bogus, I was just asking someone about you. Hope your doing OK, last time I seen you ,was on one of Mojo's crab trip, Jim.
Old Jul 29, 2006 | 02:02 PM
scott_fx's Avatar
scott_fx
you could also use 1/8" abs and fuse the monitor casing to that, paint it and then bolt it the same way that the breadbox was secured to the car.
i think either way would work well. just a question bogus. why the resin? i think 1/4" mdf would be plenty strong. is that just to seal it from moisture? I've used 1/8" birch plywood and it held a monitor nicely.
Old Jul 29, 2006 | 09:31 PM
bogus's Avatar
bogus
to start with, I am not sure how one is going to replicate the mounting of the bread box... it's screwed in from behind, so it would require adhering tabbie things to it...
as for the resin, it would make it stronger, and less prone to moisture damage.
Old Jul 29, 2006 | 09:33 PM
bogus's Avatar
bogus
wow! I haven't been on one of those in 2 years!!!
I am fine! Thanks for asking! I am in California now.
To replacing breadbox
