Sponsored by: Innova
Box Volume too small for 12" Sub
Old Jul 30, 2006 | 11:09 PM
NassauBlue98's Avatar
NassauBlue98
Default Box Volume too small for 12" Sub
What would happen if you mount a 12" sub with a recommended sealed box volume of around 1.25 cubic feet in a center storage compartment box with a volume of around 0.75 feet?
What would this sound like? I'm curious about how critical the box volume is and how it effects the sound characteristics.
Thanks.
Old Jul 30, 2006 | 11:32 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Elemental designs minimum sealed box specs is .75
Old Jul 31, 2006 | 12:36 AM
MAGRED2001VETTE's Avatar
MAGRED2001VETTE
sub will not play as deep as it should, but will most likely sould better than a 10" LOL
Old Jul 31, 2006 | 12:59 PM
fej's Avatar
fej
I would say with that much variation of true enclosure size vs recommended enclosure size you will see a pretty large decrease in performance and output/accuracy.
You can make a $15 sub sound pretty damn solid in a great enclosure, and you can make a $1000 sub sound like s**t in a poor enclosure.
You can trick the sub into thinking it is in a max of about 30% larger box than it is with polyfill. But you can hurt performance as well if you put too much inside. Example:
1.0 cu^3 box with polyfill = 1.3 cu^3 to the sub.
.75 cu^3 with polyfill = .975 cu^3 to the sub.
You would be better off doing an above the rear compartment style box to get closer to the recommended enclosure size, or choose a different sub that will be closer to the specs needed for your space. Image Dynamics IDQ will work in that size ( I have one in that size) as will the ED mentioned and the Infinity Perfect VQ 12". I am sure there are more.
I do not however recommend you build that small of an enclosure for that particular 12" sub, you will never get the output or the range that you should out of it if it were in the right sized enclosure.
Fej
Old Jul 31, 2006 | 11:39 PM
NassauBlue98
Thanks for the input, guys! Especially thanks for the examples and references to subs on the market that would work with the smaller box volume...
Old Aug 1, 2006 | 08:34 AM
byte_me's Avatar
byte_me
This man knows what he is talking about!
With his help and knowledge I purchased an ED 12" sub and one of their amps to power it...sub was $75 and amp was $175 with free shipping! it should be here today along with my Subthump 12" stealth enclosure...can't wait
Old Aug 4, 2006 | 02:09 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
One of the biggest things to remember when getting a stealth enclosure, instead of a flush mounted enclosure, is to not have the sub hitting the bottom of the compartment cover when it is playing. You will burn up a sub that way. The sub needs to move freely in order to cool a sub properly. If you impede that progress, you will heat up and melt the voice coil. Also the added distortion that sometimes accompanies added volume can damage the sub when trying to compensate for the sub being located under the stock compartment cover.
The proper airspace is critical to making sure that a sub sounds good in the box. Mordeth just recently bought an enclosure from me, and putting the sub in the correct airspace, and giving it the room to move properly has given him an extremely loud response from his new sub box...
Hope this helps!!!
Old Aug 4, 2006 | 03:20 AM
pentavolvo's Avatar
pentavolvo
This is very true if the sub hits the cover it is very very bad
Old Aug 4, 2006 | 08:03 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
This man knows what he is talking about...
Old Aug 4, 2006 | 09:18 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
I didn't know that people on here knew about eD.
Great products, great customer service.
Old Aug 4, 2006 | 10:03 PM
pentavolvo's Avatar
pentavolvo
Hehe I love ED
Old Aug 4, 2006 | 10:33 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
Hehe I love ED
ED is great stuff!!
To Box Volume too small for 12" Sub
