Sponsored by: Innova
Speaker wire color?
Old Aug 7, 2006 | 12:01 AM
ydlee24's Avatar
ydlee24
Default Speaker wire color?
I have a C6 and changed out the rear speakers but I am not sure which colors are the ground and positive? I assume like usual the darker color of the two wires is the ground right?
Old Aug 7, 2006 | 08:56 AM
DPG's Avatar
DPG
St. Jude Donor '06
ttt
Old Aug 7, 2006 | 09:50 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I'm not sure about which color is which(I'll check my service manual at home tonight), but do you realize that the signal sent to those rear speakers by the amp is mono and very low level? Changing out those speakers without doing anything else will result in.. well.. just about nothing.
Old Aug 7, 2006 | 10:42 AM
Zuntov's Avatar
Zuntov
U66 Speakers LR Midrange: Yel - / Brown +
U65 Speakers LR: Yel - / Brown +
U66 Speakers RR: LightBlu - / DBlu +
U65 Speakers RR: Yellow - / Brown +
Old Aug 7, 2006 | 01:49 PM
ydlee24's Avatar
ydlee24
Do you know the positive and negative for the center?
I have to reverse the wiring for the rears know since I thought the darker color would be the negative since black is darker than red. No wonder they did not soud as loud as stock. I have the base C6 non bose.
Old Aug 7, 2006 | 02:22 PM
Zuntov's Avatar
Zuntov
Center / U65 + U66 Speakers : LightBlu - / Yellow +
Old Aug 7, 2006 | 03:36 PM
ydlee24's Avatar
ydlee24
The center channel is what I would assume it would be since Light blue -/ Yellow +, why are the two rears reversed? dark blue, brown +? Light blue, yellow - ? When positive is universally red and negative black.
Old Aug 7, 2006 | 03:45 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You'd have to ask the engineers at GM that, but my guess is that they have to choose from available wire colors to that each wire in the car can be uniquely identified and they don't really care about which one is lighter or darker.
Old Aug 8, 2006 | 12:26 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
With the exception of some of the newer GM vehicles, most all GM vehicles follow this standard wiring code: light in the front are positive, and darker colors are positive in the rear... just think of the light provided at night... it is lighter because of the headlights shining, and darker in the rear because, well it is dark...
Hope this helps!!
To Speaker wire color?
