Sponsored by: Innova
C5 - Bad speaker relay?
Old Aug 16, 2006 | 09:52 PM
Speedway's Avatar
Speedway
Default C5 - Bad speaker relay?
Question for all you audio experts:
While back, I started to hear static out of the right rear speaker in my coupe. Initially thinking it was the speaker, I replaced it. Didn't work. Some searching led me to believe it was a bad amplifier. Sent it in for repair (corvetteradios). Got it back in...still doesn't work.
I have no bass response, and fuzzy highs out of the right rear. Could it be a bad speaker relay? If so, where is the relay located?
Thanks in advance,
Bryan.
Old Aug 16, 2006 | 10:03 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
In the c5 the front tweeters and rear speakers are all powered off of the actual indash radio.
Old Aug 16, 2006 | 11:08 PM
scott_fx's Avatar
scott_fx
i don't think that the c5 bose has speaker relays and all that the relay would control is the amp turning on or off. penta is right though and the rears are powered off the deck. so you may need to have the deck repaired. if you are in socal i can let you borrow my deck to test it out.
To C5 - Bad speaker relay?
