Sponsored by: Innova
CD Changer
Old Aug 25, 2006 | 05:12 PM
Sadie's Avatar
Sadie
1st Gear
Default CD Changer
Just picked up my 2007 Corvette C6 Base Coupe yesterday morning. I ordered the car with the navigation and Bose, so I only have the single CD player. Just wanted to ask how difficult it would be to install the GM 6 CD changer. I was told by another Corvette owner (has a 2006 ZO6) that the wiring harness is already installed from the dash to the left rear wheel well. All I would have to do is mount the changer and a short wiring harness. Do you know if this is correct. Or do I have to run a wiring harness from the dash to the left rear storage compartment? Thanks, Phil
PS - Where's the best place to pick up a GM 6 CD changer?
Old Aug 25, 2006 | 05:18 PM
Keith N's Avatar
Keith N
You probably want ask some audio guys regarding the install, but it has to be fairly simple.
Check out Fred Beans (CF Vendor) -they were running a special price on the GM 6 CD Changer.
Old Aug 25, 2006 | 05:53 PM
nakia's Avatar
nakia
2nd Gear
I just bought my 07 c6 convertible and i ran into the same problem. It's not a problem at all. just make sure you order the right one. There is one for the coupe and another number for the convertible. The reason is the wiring harness that is included is different. I did mine myself in about 45mins. Easy install
Old Aug 27, 2006 | 09:16 PM
Rickmd's Avatar
Rickmd
Did you use the expensive GM accessory CD changer? Does it operate through the radio controls?
Old Aug 28, 2006 | 01:04 AM
rothchilds's Avatar
rothchilds
why not just make some MP3 discs?
To CD Changer
