Sponsored by: Innova
alpine in 94 help
Old Aug 26, 2006 | 10:06 PM
JRS 94's Avatar
JRS 94
Default alpine in 94 help
Installing an alpine head unit, problem is ---- where is the antenna connection, I don't see a coax anywhere?
Also, I have the wrong wire adapter, the 94 vette was non bose with am fm cassette, does anyone have a schematic of the wiring harness (the original is 2 pieces with 14 wires) or a part number for a wire harness adapter? I'd like to use the switched power, the antenna power, and the dash light dimmer at a minimum. I am adding an amp and subs, no problems there, just don't understand the antenna and the wiring harness. Any help would be appreciated.
Everything is in the back in the passenger side storage bin? Did I figure it out?
Never mind all set.....
Old Aug 28, 2006 | 11:42 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default Read
The FAQ @ the top of the section
