Sponsored by: Innova
Quick Speaker Question for a C5
Old Sep 1, 2006 | 07:15 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default Quick Speaker Question for a C5
I read the sticky, great info...
I was talking to the audio installers at a well known retail chain (this should be good) and they said I can't just replace the speakers in the C5, because they are designed to work on 4 oms, and the bose system works on less than 2 oms. They said that if I do it I would blow the speakers?
From what I read in the sticky, I should be able to just replace the speakers with aftermarket speakers, right?
Tks
Peace
Willfulone
__________________
..................Click for
Old Sep 1, 2006 | 07:39 AM
knewblewkorvette's Avatar
knewblewkorvette
"They" are wrong. The 3.5" twiddler and the rear speakers (either 5.25" or 6.5" dependent on model) can be swapped out with no problems with aftermarket 4 ohm speakers. "They" are thinking of older Corvettes.
Many C5 owers have done the swap and are pleased with the results. I recommend doing the 3.5" first. Infinity and Alpine seem to be a popular choice.
Old Sep 1, 2006 | 09:12 AM
DPG's Avatar
DPG
St. Jude Donor '06
you can swap those out.
Old Sep 3, 2006 | 03:16 AM
TA8088's Avatar
TA8088
I've been talking to the installers that did my Hummer for a couple months now about doing an install in the vette and what my options are. I have an Alpine CDA-9855 HU in the garage and and they told me that using that with a PAC adapter and upgrading the 3 1/2"s with a set of alpine's would be a big improvement. They have upgraded the twiddlers on a couple of cars by installing the 3 1/2" Alpines and said that it was a nice improvement. The new LT's drowning out your audio?
Old Sep 12, 2006 | 03:30 PM
Ephedranator's Avatar
Ephedranator
I am also replacing my speakers, but I want to go bigger than the 3.5 twiddlers, but since I am keeping my radio stock, is there a law a deminishing returns on the power handling and quality of speakers I put it with stock amp?
Anyone else have this concern?
Old Sep 12, 2006 | 04:54 PM
scott_fx's Avatar
scott_fx
you'd have to completely remove the bose speakers/assembly and get an amp and speaker combo if you want to do anything but replace the 3.5" twiddlers in the doors. you can keep the factory head unit though. you'll just need a soundgate or pac-audio bose interface.
Old Sep 12, 2006 | 05:35 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you can remove the bose enclosure and put a 6.5 in the door or something which will sound better then a 3.5 but you will loose the bass you had
To Quick Speaker Question for a C5
