Sponsored by: Innova
LED question
Old Sep 8, 2006 | 11:19 AM
Mr. Blue's Avatar
Mr. Blue
Default LED question
I know that it's not audio, but IT IS electronics.
I installed a set of the halo LED tail lights, and I have a sequencer installed also. I have the "fast blink" syndrome. Is there a fix for this that will let me keep the sequencer in the circuit?
Old Sep 8, 2006 | 12:46 PM
scott_fx's Avatar
scott_fx
i believe it's done with a resistor. it's a common problem with bikes when we change out our turn signals. Sorry i'm not much help but maybe that will get you pointed in the right direction
Old Sep 8, 2006 | 03:34 PM
MAGRED2001VETTE's Avatar
MAGRED2001VETTE
The blinker relay and flash rate works off of the load (resistence) in the tail lamp.
Scroll down in this link, you will need one for each tail light...
http://www.superbrightleds.com/cgi-b...2.1140&next=50
Old Sep 8, 2006 | 06:37 PM
Fasthotrod's Avatar
Fasthotrod
You guys are right on the money!
The flasher works by (and is dependent on) the amount of current flow in the flasher circuit. The flasher uses a bi-metal tab that works like a relay contact. As the current flows though the bulbs, heat is generated in the metal tab, causing it to bend and opening the circuit. The metal tab cools and the circuit is re-enabled. Blink-blink-blink.
LED's are much, much more efficient at producing light, therefore are low current devices. They just don't pull the current required to heat up that element properly.
Using a resistor for each taillight blinker should cure your 'quicky-blinky' problems. Just place it in parallel with the LED terminals.
Hope this helps.
Mark
Old Sep 9, 2006 | 07:30 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Since the Halo LED lights already have a resistor circuit built into each light the problem is with the taillight sequencer. From what I have gathered from others that have tried this is the LED's and sequencer are not compatible.
To LED question
