Need help with C3 convert system
Let me say up front...I don't know anything about stereo systems except what I have read here over the last couple of weeks. What I have read tends to confuse me more than help me to tell the truth.
Engine performance is sooo much easier.I have found a HU that really impresses me. I found it in the post about not wanting it to look like a rocket ship, or something like that.
I really like the Pioneer DEH-P880PRS and have pretty much decided that is what I will get. Now the problem comes in picking out front speakers and an amp to drive them. I'm planning on buying the Kenwood powered Sub that is packaged for tight spaces. It is part number KSC-SW1. I don't have much of any space in the rear area, and with the top down that small space is almost half the size. I don't expect thumper type bass, just solid lows.
I don't need/want a system that is designed to impress people from down the block, not to mention the police. I'm looking for a nice clean sound with enough power that will allow me to hear it with the top down on the freeway. I realize that cars tend to be hard to get great sound out of, and mine is probably worse being a convert. I listen to everything from Country to Motown to Rock (AC/DC, Led Zepplin, Rolling Stones, etc.) to AM talk radio depending on my mood.
What front speakers, 4x6"? would you suggest, and where would you suggest I install them? The dash, the kickpanels, or both?
What amp would you suggest to drive the front speakers? Would it be worth while to install two sets, one in dash and one in kicks? Which area would give the best sound if only one set is used?
Thanks for any and all help in advance.
Jeff
I used to have a 74 as well. just not a convertible. one of my fav cars that i have owned. i miss it. Take some pics of the interior so others know what you are working with as far as interior space. and locations as well.
I have an '80 and I decided to keep it simple and put 4x6's in the dash. But then I have a lot more space in the back than you do and was able to put a pair of 6x9's in a box. I decided early on that the '80 was just never going to be quiet enough to appreciate really good stuff like I've done in my C6 so I went the "update" route, an Alpine 9851 and Kicker speakers front & rear.
A couple of things to keep in mind as you plan it out - the dash area is very small and you may very well have to mount the crossovers with the amp and just feed speaker wire up to the dash and/or kicks. Also to mount a modern single DIN head you're going to have to cut your bezel to get rid of the 2 post opening. It's a simple thing to do, but many folks wince at the thought of cutting on the bezel. Aftermarket bezels are available that are ready for single DIN units so you could put aside your original if you were concerned about that.
I'll second DPG's request, pics of the interior so we can get an idea of the space.
I don't have my camera. It should be back by this weekend. I measured the open area in the rear with the top lowered. I only have 7" of height where the top ends up. There is room behind there that goes the total of about 13" high. There is a interior light that is mounted in the exact center of the rear panel.
I have seen the Infinity 4x6 seperates where they mounted the mid and tweeter seperate on a 4x6" panel. They are designed to go into the stock mount area. The shop that I looked at them didn't have them hooked up to an amp so I don't know how they would sound with some power behind them.
Where is the best arear to mount this type of speaker? The kick panels or the dash? And what amp would you suggest to power them?
Or am I better off mounting two sets, one into each area? If so, what amp would you suggest to power the pair?
Thanks,
Jeff
Thanks,
Jeff
http://www.polkaudio.com/caraudio/products/mmc460
Or the Boston Acoustic 746? Don't have a link handy at the moment, sorry.
Thanks,
Jeff
Last edited by 406shark; Sep 13, 2006 at 12:10 AM. Reason: added another speaker to the mix.
Also, the standard polk db line is very nice as well as the infinity 4X6s that arent in plate form
Also did you want to try and run rear speakers or a sub or osmething like that
Doesn't mean other things can't be done, just depends how much fab you want to do and how much money you want to spend!
I plan on using the Pioneer DEH-P880PRS HU. A Kenwood KSC-SW1 self powered sub in the rear. Sounds like the Polk/Momo MMC460 speakers mounted in the kick panels. The kick panel area is set up for 4x6 speakers. The C4-C6 have tons of room in them compared to the C3's. I don't want to hack up the interior, or spend tons of cash. I have an extra gauge bezel that I can cut for a DIN opening so that is covered.
What amp would you suggest to work with the MMC460 speakers taking into account the rest of the system as outlined above?
Thanks for the help,
Jeff
Thanks,
Jeff
If not, this phoenix gold will work great and its a pretty small footprint and a killer price http://sonicelectronix.com/item_1584.html and would power those speakers nicely, actually it matches there rms exactly, you could always get something more powerful but ur speakers can only take as much as this puts out. This amp might be a bit less on ebay but sonicelectronix is a good company to work with.
or for a few bucks more pick up this mtx, a bit nicer of an amp http://sonicelectronix.com/item_6878.html
For wiring check out knukonceptz.com and grab there 2 channel 8 gauge kit it will have rcas for ur sub and the speaker amp and the 8ga could power it all.
Thank you to everyone for all the help, especially Penta, on helping to pick out components that will work together for me. I really appreciate it.
Jeff
Good idea. I'll make sure and do that. I may take you up on the offer of assistance.
Thanks,
Jeff
I decided to spend the extra money and buy everything from Sonic just to make things easier if I have problems down the road. I also ordered the adapter that allows you to hook up an IPOD to your system instead of trying to fit a changer in back. I don't even own an IPOD! I figured if I was going to go to all the work of installing a new system I would just do it right and hook everything up from the beginning.
I'll have to study which IPOD will work best for me.
Thanks again, and I'll start a new post when I do the install on my '74.
Jeff
