Sponsored by: Innova
lead screw help
Old Sep 21, 2006 | 09:40 PM
scott_fx's Avatar
scott_fx
Default lead screw help
does anyone know anything about lead screws?
what kind of motor would i need to power this thing?
http://cgi.ebay.com/Kerk-Lead-Screw-...ayphotohosting
and how do i hook it up? I'm hoping to keep costs down so if powering this thing is too much i may end up scrapping it and going with option b
thanks
Old Sep 21, 2006 | 10:10 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sounds like ur looking to power something and make it move... my recomendation is pick up some used power seat rails from a car try a junkyard etc... weve done it before
Old Sep 21, 2006 | 11:21 PM
scott_fx's Avatar
scott_fx
but but...this is sooo cool!!!!
Old Sep 21, 2006 | 11:34 PM
adown's Avatar
adown
Scott, motor size depends on what your trying to move with it. I would say some type of gear reduction or low rpm motor to lessen the drag on the motor. As far as a coupler you could gring a flat spot on one side so it's D shaped like most motor shafts and use a set screw. Graingers should have everything you need.
Old Sep 21, 2006 | 11:37 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
thanks
Probably some sort of worm drive (screw) motor... This should be a smooth quiet movement, with smooth transitions... I personally have some cool actuators...
Old Sep 21, 2006 | 11:55 PM
scott_fx's Avatar
scott_fx
graingers, got it! thanks. I'll check it out now.
Its a really light panel that i'l be moving. so i dont think it needs to be that strong
Old Sep 22, 2006 | 12:23 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
Awesome.... pics please when you are done...
Old Sep 22, 2006 | 09:04 AM
DPG's Avatar
DPG
St. Jude Donor '06
if you ever decide on a final product and finish
Old Sep 22, 2006 | 10:17 AM
Duramax Dave's Avatar
Duramax Dave
Haha...so true. Scott likes to change his mind a lot. But it sure is going to be sweet when it's done.
Old Sep 22, 2006 | 01:00 PM
scott_fx's Avatar
scott_fx
To lead screw help
