The C6 amp is under the pax footwell area. That info will not help you out too much. What do you really want to do?
i want to know if the signals from the HU are split up (ex:low freq vs. high/mid) to go tothe respective amp. aren't the subs powered by a different bose amp than the door speakers?
also, if the rears are mono, is the signal coming out of the head unit mono or is the bose amp combing a signat to make the rears mono?
The HU puts out clean full range audio. The amp also acts as a crossover and sends mono signals to the real. There are many recent posts dealing with how to take the PAC OEM GM-24 and use it as a breakout cable. The C6 FAQ (top of page) has pics and insructions. Good luck!
logjam got back to me and stated that this adapter will not work for my car. i have a 2005 w/ the nav HU
Please check out the FAQ. It will not work as a direct plug in very well (OMG PAC is correct! ). Your questions have been addressed at least 5 times this week alone. It will work with some modifications.
