Sponsored by: Innova
Installed system, Time to tune it up ...
Old Sep 25, 2006 | 04:57 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Dave you always have a winter project... I have mounted amps behind the seats in a number of C5s and no problems of yet
Old Sep 25, 2006 | 10:07 PM
DPG's Avatar
DPG
St. Jude Donor '06
it seems like i do
Old Sep 25, 2006 | 11:07 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Ok, so I decided to take a drive tonight and push the new system a little bit since I didnt want to hear the neighbors complain. I mean, the only way to really check out your setup is to push it a litle bit yes ? I set the gains basically to stop muddying up/distortion at HU volume level of 27 (out of a max 35).
Five minutes of pushing the system at vol 25 the heat buildup in the amp was a bit surprising. It was not only warm, but really warm. Dropped the drivers window and let the cool Northwest air rush in, comfortable, not cold, and it helped tremendously cool the amp.
Ive got to say though, I am absolutely tickled at the quality of sound from these Balupunkt's. Keep in mind these same speakers/amp/sub setup came out of a full size Chevy 2500HD. Slightly different environment. The major difference with the sub is I went from a downfiring box with less than desireable volume to a stealth box with appropriate volume and firing up to the top of the rear hatch.
The heat issue concerns me a bit, but, it should be fine as long as I don't hammer on it too much
Old Sep 25, 2006 | 11:18 PM
pentavolvo's Avatar
pentavolvo
naturally some amps are warmer then others. I have a Polk 4 channel and it likes to run warm its the nature of the beast, I have an elemental designs mono block i run 1200wrms + through it and it stays damn cool
Old Sep 25, 2006 | 11:27 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Glad to hear everything sounds great in your Corvette!!
Old Sep 26, 2006 | 12:38 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Thanks Dave. Gimme a couple weeks and I'll get that cover shipped to ya.
Old Sep 26, 2006 | 12:40 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
I dont think it will become a major problem. At volume lvl 25 on the HU, my ears will start bleeding in short order. Although, the sound is absolutely amazing at 25
Old Sep 27, 2006 | 01:43 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
The stealth box fits well, maybe too well. With the cover on I think the sub at higher volume levels tops out against the cover. Not too worry, I dont max the volume much but the problem is the cover really deadens the sound. Thinking of maybe switching to a flush mount box and investing in a sub grill.
Buy one of these. They are made of steel:
http://cgi.ebay.com/ebaymotors/Kicke...QQcmdZViewItem
I have one on my 10" sub and can throw boxes, crate of parts, tool box, etc around in the back and it holds up really well, plus looks cool
man, after seeing the behind the seat installs, I think im going to break down and just do that again. I used to have mine behind the seats, but moved them to the upper deck so I could adjust them more often.
Old Sep 27, 2006 | 08:59 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Slick looking grill. I am probaboly going to remove the amp and place it on the back wall of the hatch area. I lost a full 3inches, maybe a tad more, of seat travel on the pass side. For now it's fne, but I will move it in the future. Something about being able to stretch out, at least more than I can now, when I am actually riding and not driving.
