Sponsored by: Innova
JL8W7 too small?
Old Oct 14, 2006 | 06:52 PM
JimmyZ78's Avatar
JimmyZ78
Default JL8W7 too small?
Is a JL8W7 too small for a vette? I have MB Quart Prem's for mids and highs, JL8W7 and a JL500.5 amp. I see boxes from subthump for 1 10 or 2 10's or 1 12. What do you guys think? If I go with a bigger sub, then I'll have to get another amp or sell this one and get two amps, one for components and one 500w + for the bigger subs. Thanks
James
Old Oct 14, 2006 | 07:49 PM
bogus's Avatar
bogus
Nelson V. had a pair of 8W7s in his C5 roadster... and that ****ing ROCKED. I was seriously impressed.
Old Oct 14, 2006 | 08:10 PM
JimmyZ78's Avatar
JimmyZ78
Maybe I'll try one. I'd have to buy not only another 8 but another amp or two as well.
Old Oct 14, 2006 | 08:36 PM
bogus's Avatar
bogus
how much power do you have now? A single 500 watt amp will drive both just fine.
Old Oct 14, 2006 | 09:04 PM
JimmyZ78's Avatar
JimmyZ78
A JL500.5 is a 5 channel amp, 100x2, 25x2, and 250x1. Its basically a perfect amp for 1 8" sub. If I were to sell it and the sub I'd have to buy two amps and two subs...
Old Oct 14, 2006 | 10:48 PM
knewblewkorvette's Avatar
knewblewkorvette
I'm sure he'll make you a box for a 8". If not, member Audio Dave will For SQ, 250 watts rms and that 8" will get along fine. The JL 8W7 can kick allot of 12" models out there.
Old Oct 14, 2006 | 10:49 PM
knewblewkorvette
Oh, by the way, welcome to the best forum on the web
Old Oct 15, 2006 | 12:18 AM
JimmyZ78's Avatar
JimmyZ78
In my old 00 Silvy Ext Cab, I had the Alpine CDA9811, MBQuart Premium's, JL8W7, JL500.5 and a cap. Along with dynamat. I used to compete in sound quality shows and would get second place every time. Only because I wanted a stealth set up and that made my stage too low. I know the 8 will be loud enough, just not sure if its the way to go. I pm'd Dave already, just patiently waiting a reply. Thanks
Old Oct 15, 2006 | 08:16 AM
adown's Avatar
adown
I've not run a single 8", but I have a pair of Rockford FNQ 8" in my 88. It sounds good and hits hard(for 8's), but am going with a single 12 in my new project for more low end punch. It all depends on what sound your looking for. I'm sure you saw the big debate on speaker performance acording to size.
Old Oct 15, 2006 | 02:11 PM
JimmyZ78's Avatar
JimmyZ78
Yeah I saw the debate and don't want to bother with another one. I listen to all sorts of music, rap, r&b, alternative, country. Just depends on what I'm in the mood for. The JL500.5 has a remote bass controller that I mount close to me, so if I feel the song needs more bass I just turn it up a little. I'm trying to skimp a little and not have to buy anything else for the time being. I haven't even picked up the vette yet, so I'm already planning. Next weekend
Old Oct 16, 2006 | 12:14 AM
scofolo's Avatar
scofolo
I'm planning on doing a similar setup with the 8w7 running off of the 500/5. I can't wait. It is an awesome sub.
Old Oct 16, 2006 | 01:05 AM
JimmyZ78's Avatar
JimmyZ78
What if I bought a JL 250.1 and got a JL10W7 and ran my 250 watts from my 500.5 to one VC and the 250.1 to the other VC, will this work?
Old Oct 16, 2006 | 08:53 AM
adown's Avatar
adown
I don't see why not. As long as you know each coil is getting 250wts. I read an article where the tester from car audio was testing the new Pioneer 5102 and the only way he could get enough power was to run 1000wts to each coil from 2 amps.
Old Oct 16, 2006 | 03:17 PM
j99vette's Avatar
j99vette
I personally wouldn't do it. Does the 500.5 have a seperate gain setting for the sub channel? If so then I would think it would work and suggest having both amps run through the same fuse.
FWIW. I think you would be fine trading the 8 for a 10 and not getting another amp. 250w would be plenty for a 10 in the vette. good luck
Old Oct 17, 2006 | 11:05 PM
wicked 98z's Avatar
wicked 98z
ive got a jl10w7 and a 500.1 and its crazy loud.. Just be carefull now my driver side window has became loose or something its making a noise now.
Old Oct 17, 2006 | 11:13 PM
VinceC5's Avatar
VinceC5
the coils would be getting a different signals and therefore not sound right.
I had the 500.5 on two 10w0 and was more than enough power.
Old Oct 19, 2006 | 05:57 PM
rmp's Avatar
rmp
I installed an 8 in CDT subwoofer powered by an Alpine M450 (220 watt) amp and I think it provides more than adequate low end punch but I don't listen to rap or want to turn heads at the stop light and don't want my car to rattle apart from monster low frequency vibrations. You can see my setup at "DIY subwoofer" in this Forum. =JimmyZ78]Is a JL8W7 too small for a vette? I have MB Quart Prem's for mids and highs, JL8W7 and a JL500.5 amp. I see boxes from subthump for 1 10 or 2 10's or 1 12. What do you guys think? If I go with a bigger sub, then I'll have to get another amp or sell this one and get two amps, one for components and one 500w + for the bigger subs. Thanks
James[/QUOTE]
To JL8W7 too small?
Old Oct 19, 2006 | 06:19 PM
scott_fx's Avatar
scott_fx
If you are considering getting another sub: i just talked to the reps at jl and he is running a 12w7 with a 500/1 and he says it's pushing it just fine, it's not underpowered at all.
Old Oct 19, 2006 | 06:25 PM
Steve Germany's Avatar
Steve Germany
I just replaced my Alpine 300 watt sub amp with a JL 250 / series and there is absolutely no comparing the difference. Absolutely unbelievable. It is like comparing a Kmart butter knife to a Schlenger knife.
Old Oct 21, 2006 | 06:52 PM
scott_fx's Avatar
scott_fx
just read this... not that wouldn't work. personally i wouldn't even do that if i had a two chan amp and running each chan to a voice coil. lets say that you set the gains exactly and have an oscilliscope and have both outputs with exactly the same voltage. everything is good and fine, but 6 months down the road one chan's components partially fail and it affects the output. now you are having each voice coil having different wattages and that will lead to premature speaker failure... thats asuming that both chans are from one sub. now when you introduce two amps (that aren't strappable) you are playing with fire.
on a related note that i found interesting; the w7's specs are supposed to be in such tight tollerances that if you push down on the cone you could feel friction if the force isn't evenly distributed.
