I have a pair of Infinity Kappa 5 1/4" component speakers and I was wondering if I could wire the mid and tweeter in parallel for a 2 ohm impedance and not use the crossover it came with.
I'm going to use the high pass crossover from my amp and I wanted to wire the speakers for a 2 ohm impedance because the amps power into 2 ohms is 100 watts rms compared to a 4 ohm impedance which is 75 watts rms. Thanks.
Technically you could but you will most likely blow the tweeter. The tweeter needs to be xover at a higher frequency then the 5.25. You are better off using the xover.
I forgot too mention I was also, going to install some bass blockers I had for the tweeters but, I'll just use the Infinity crossovers just to be safe.
All you need is a capacitor in series with your tweet and a coil in series with your mid. It is doable, you just need to know where you want to cross at.
you could use the x-over on one of them and then a cap in series with your tweet. though this would be a 1st order x-over (is that 3 or 6 db/oct slope? I forgot)
There is no point in using a cap and coil if there is a predisgned xover network already made. Once the cap is introduced the tweeter is no longer going to play the same frequencies as the mid driver therefore the amp is not going to see 2 ohm. The amp will only see 2 ohm or lower when both speakers play the same frequency at the same time.
I had always wondered about that.. I heard it once before.. it does make sense..
I'm not worthy! I'm not worthy! Eatrice - thanks for being here!
1st order is 6db. E R is right that the amp wont see 2ohms. The cap is a linear device and is going to add impedance. Actually the same is true with any passive xover. Caps and coils introduce impedance.Digital or active are the best.
Scott, in parallel it would be 2.66. In series it would be 12. Of course passive xovers are going to add some resistance. Then it gets complicated with frequency and cutoff formulas, but 4 ohm speakers aren't really 4ohm. Their more like 3. 6 or something.
A tweeter with a 1st order xover could introduce as much as 16 ohms at 5000hz and drop power by 2/3. So instead of 100 watts your tweet would see 25watts You would have to know what order the xover is and the target freq.
