Sponsored by: Innova
dynamat
Old Oct 19, 2006 | 11:52 AM
x-mann's Avatar
x-mann
Default dynamat
my installer recommends using this stuff in the door panels. he says at least 1 sheet per door, 2 would be better. also, along the floor of the cargo area. his price is $25/ sheet. does this sound reasonable?
Old Oct 19, 2006 | 12:06 PM
adown's Avatar
adown
Depends on how big a sheet is. Check ebay for prices.
Old Oct 19, 2006 | 01:09 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
edesignaudio.com search forum and look at edead same **** way less expensive... there are tons of deadeners online for way less then the cost of dynamat and they do the same thing
Old Oct 19, 2006 | 03:02 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Second on eDead. It kicks a$$
If you HAVE to use Dynamat - get Dynamat Extreme. Head and shoulders above standard Dynamat.
Old Oct 20, 2006 | 01:44 AM
wiz1500's Avatar
wiz1500
Now you tell me.....
These guy's are right you can find much beter deals on the net...I was luck be no means did I pay close to MSRP for the 100 sq I put down..
Old Oct 20, 2006 | 01:56 AM
onaqwst's Avatar
onaqwst
a bit dirty
b
Old Oct 20, 2006 | 10:05 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Any opinions on the different versions of eDead on the ED website ? From the 1 buck a sq ft rolled stuff to the liquid ??
Thanks !
Old Oct 20, 2006 | 10:38 AM
pentavolvo's Avatar
pentavolvo
liquid is kinda a pain in the *** but really nice DPG will chime in on that... i always use V1SE2 best bang for the buck IMO
Old Oct 20, 2006 | 10:44 AM
0EG@EnglandGreen
Supporting Tuner
I used eDead v1.2 inside and v3 liquid under the entire car outside.
Used Dynamat Extreme inside and outside the doors last year. Didn't replace it with eDead (way too much work)
Old Oct 20, 2006 | 01:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
both have their positives and negatives. I kinda liked the liquid because you dont have to measure and cut anything. You just brush it on and let it dry. There was a smell for a week, but barely noticable. Im sure it would have been shorter if i hadn't done it in the dead of winter. But liquid and mats each cancel out their own set of frequency ranges. eD has a ton of info on their site about it. If anything mat the doors adn trunk area. You can also buy the pre cut stuff from crazy cowboy. Do a search for his stuff and there is nothing but praise for his products.
Old Oct 20, 2006 | 02:38 PM
DPG's Avatar
DPG
St. Jude Donor '06
http://forums.corvetteforum.com/show....php?t=1335784
Old Oct 20, 2006 | 03:05 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
I didnt even bring up the precut pieces from the crazy cowboy, that was going to be left for a seperate question, but honestly, since they are ALL related, ok... I apprecaite the info. I am simply looking for the least painless installation vs best quality for the buck ... maybe im wrong, maybe im right, either way, ... nm, im rambling
Thanks guys !
Old Oct 24, 2006 | 01:05 AM
VinceC5's Avatar
VinceC5
Everything you ever wanted to know about sound deadners
http://www.sounddeadenershowdown.com/
To dynamat
