Sponsored by: Innova
amp by pass...
Old Nov 15, 2006 | 02:53 PM
not08crmanymore's Avatar
not08crmanymore
Default amp by pass...
Is /are AMP BYPASS'S needed when installing aftermarket radios in a c6 with BOSE??I think BOSE SPEAKERS have/had individaul amps for each speaker,right??
Old Nov 15, 2006 | 03:52 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
The Blose units in the C6 have only one amp located in the passenger side foot-well next to the fuse box. If you want to install an aftermarket HU while keeping the Blose speakers you will need some converters. Like the Peripheral GMAH24 and the GMAHCM, or the PAC AOEM-GM24. However, why anyone would want to keep the Blose speakers and amp is beyond me since THAT is the weak link of the Blose system, not the HU. You will be better off replacing the whole damn thing...at least IMO.
Old Nov 15, 2006 | 06:24 PM
not08crmanymore
Default system
_Nomad_
Well,as always,money is a factor! So,would you reccomend changing out the speakers instead??
Old Nov 15, 2006 | 06:58 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
unless you plan on amping them and adding a sub etc u might be better off sticking with the stockers
Old Nov 16, 2006 | 07:40 AM
not08crmanymore
Not doing all that.So,Just 1 by pass for one speaker amp will do the trick for stock speakers?
To amp by pass...
