Sponsored by: Innova
problem grounding the amplifier??
Old Nov 15, 2006 | 11:14 PM
spiral04's Avatar
spiral04
Default problem grounding the amplifier??
I decided to ground my amp to the frame just above the mufflers, but that didn't work, I don't know. When I ran the ground to the battery it was fine. So, it's the ground's connection. In the c5 audio faq's it says to ground the amp to the screw/bolt that holds the rear middle compartment to the fame or to the seat bolt (don't want to do). Where is this screw/bolt that holds rear the middle compartment to the frame????
Old Nov 16, 2006 | 09:39 AM
DPG's Avatar
DPG
St. Jude Donor '06
i know in mine its where the baby seaat thing is i believe. In the FRCs its behind the passenger seat and its a small hook that sticks outta the carpet. Im sure that is anchored to the frame
Old Nov 16, 2006 | 12:39 PM
spiral04's Avatar
spiral04
Ttt
Old Nov 16, 2006 | 02:22 PM
EatRice's Avatar
EatRice
Your ground to the frame is the best location. Did you ground it near the factory ground in the wheel well? Did you scrape the paint off? I would also check your factory grounds on the battery to make sure they are solid and clean.
To problem grounding the amplifier??
