Sponsored by: Innova
About to install sub/box/amp, quesitons....
Old Nov 22, 2006 | 11:54 AM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default About to install sub/box/amp, quesitons....
I picked up a used box/sub/amp from a forum member this week. It's a 10" Diamond sub and 200w Fosgate amp, with a custom box built to the dimensions often posted on here. I have the factory Bose system in my 01, and the 12 disc changer mounted in the center compartment.
I asked a few car audio shops what it would take to get it running. From what I've found, I need a converter that plugs into the factory HU to get it running. Shop said this is about $20. I also need an amp wiring kit, about $45. I know I could have picked up this stuff online for 1/2 that, but it's too late now.
I'm thinking of buying the parts and tackling this with a friend to save some cash and get some satisfaction. I've also read that it's really not very hard to install this into C5s.
Question time:
1) How do I get to the back of the HU to plug in the connector?
2) Is it easy to move the changer over to one of the side compartments? I need to do this to fit the box.
3) I know I need to run the cable from the battery through the rubber grommet in the firewall. WD40 can help, sound accurate?
4) What rear carpet/panels do I need to remove to run the wires to the changer, amp, and sub box?
5) Where do I run the cables that go through the firewall? And what side panels do I need to pull to get to the carpet?
6) Can I mount my amp, it's pretty small, in one of the side compartments?
7) Are there some install pages with detailed pics to do this?
Thanks for any help!
Old Nov 22, 2006 | 12:52 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sorry for the short post check the C5 FAQ at the top of this page, I know for a fact between the 3 pages theres 2 diff install writeups and other helpful info... Im gonna PM you my cell phone number in case you need any help as well I kno the car inside and out
