Sponsored by: Innova
Would like to replace stock '03 speakers
Old Nov 26, 2006 | 12:05 PM
solo25's Avatar
solo25
Default Would like to replace stock '03 speakers
I've read a lot on these forums, and talked to a couple of guys at stereo shops. From what I read, I can simply remove and replace the stock Bose speakers that are there. The stereo shop guys say I have to replace everything. Can someone please tell me which speakers will work with the Bose headunit? I'd like to replace the 3.5's, the 8" woofers, and the rear 6.5s. Any help would be appreciated. And also, please be specific, as I know nothing about ohms and stuff like that.
Thanks,
Mike
Old Nov 26, 2006 | 03:21 PM
bogus's Avatar
bogus
Have you reviewed the C5 Audio FAQ? I know it will have the breakdown of what has to go and what does not.
Old Nov 27, 2006 | 02:11 PM
solo25's Avatar
solo25
I guess I'm having a little trouble tracking that down. I have found some FAQs, but not much specific. I'll keep looking. Thanks.
Old Nov 27, 2006 | 04:39 PM
scott_fx's Avatar
scott_fx
Thanks,
Mike
you can replace the rears and 3.5" front speakers with similar sized 4 ohm coaxials. the subs have to stay though
Old Nov 27, 2006 | 07:00 PM
fej's Avatar
fej
What Scott said. The factory 8" "subs" are powered by their own small amps located as part of the speaker mount assembly behind the 3.5" twiddlers (not real tweeters .. not really mids ... just blose crap). The 3.5" speakers in the front doors and the rear speakers are 4 ohm units (most everything for car audio is 4 ohms for stereo applications, IE not subs) and can be replaced by any 3.5" (front) or 5.25 or most 6.5" speakers for the rear. You can utilize the factory wiring in both instances. The 8's are like 1.5 ohms .. not upgrade friendly at all.
Look around through some of the system threads .. there are many paths to take in regards to upgrading the factory blose system .. all of which result in improved sound. My advice if you enjoy your audio at all is to figure out a budget you would be willing to spend for upgrades and let us provide you some options within that budget.
Fej
Old Nov 28, 2006 | 07:03 PM
solo25's Avatar
solo25
Thanks for the reply. I was thinking about just doing speakers, but if it's going to take more to get good sound (and I do like to hear good quality), I'd be willing to spend about a grand. What do you suggest in that price range? I can do most, if not all of the work myself.
thanks,
mike
Old Nov 28, 2006 | 07:26 PM
scott_fx's Avatar
scott_fx
i'd say go with a nice 2-way component system up front... cdt or elemental designs come to mind. a nice moderate sub; jl, Image dynamics, elemental designs. and a 4 chan amp...again, elemental designs nine.4, xtant (used 603x or was it x603), phoenix gold 500.4 ti or zx.
Old Nov 28, 2006 | 07:58 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Thanks,
Mike
The headunit isn't Bose. Its your basic Delco. It's the Bose amplified speakers and Bose electronics between the headunit and speakers that makes the swap difficult.
There are companies, such as PAC, that make adapters to keep the stock headunit and replace the Bose speakers with most any aftermarket speakers.
Old Nov 29, 2006 | 04:29 PM
scott_fx's Avatar
scott_fx
for $500 you could get a killer 2 amp combo:
http://www.diymobileaudio.com/forum/...ead.php?t=7022
you could do a fully active 2 way setup with sub. i actually have a zapco active x-over if you were interested too :-)
To Would like to replace stock '03 speakers
