Am I headed down the right Path Audio Gurus?
I have decided after three yrs. of ownership of my '04Z that I am going to completely replace the stock stereo (up to this point I had added an aftermarket changer and replaced the 3-1/2 front and 5-1/4 rears, but otherwise remained stock).
So far I have purchased an Eclipse CD5000 HU w/ IPOD module, GPS module, and an Eclipse 8-disc CD changer; I don't beleive the Kenwood I have was going to integrate easily.
I plan to purchase JL Audio 300/4 and 250/1 amps, JLAudio stealthbox w/10W3 sub and JL Audio ZL650CSI, ZL525CSI's to replace existing speakers.
Not sure of how or where I am going to mount the amps. THe two options are in a low profile box just behind the seats behind the cargo ridge or mounted to the backwall. This would have to be configured so that I could still use my partition if I choose to. My objective is to have a very high quality sounding system with minimal intrusion/space given up. Any advice as to where to look for a custom box? I would build this myself but really don't think I have the time do this (I may have to have the install done professionally for the same reason). I thought I might favor the amp box because it would provide an accessible place for me to mount the speaker crossovers as opposed to in the doors. Again, I don't want this to be very noticeable, I prefer a stealthy set-up as a prime objective.
Thoughts? Advice?
Thanks!
As far as the box....Id be happy to build you a fiberglass box if I could find someone in the Chicago area to let me take a mold of that area...
How is the HU itself? I chose it do to recommendations and it's features...
as far as the jl components. if you liked the way they sounded, they were in your price range then you should be good to go. jl makes quality components. you're not getting low level stuff. most important is how you like the sound. not us.
as far as getting the four chan amp. you could do this, but i'm not sure you will see a lot of advantage out of this. maybe if your deck has time alignment or you want to play around with mixing and matching different drivers from time to time (it's fun, ask -=jef=- and fej) but if you like having rear speakers you may not appreciate that feature so personally i'd save the money and get a jl 2 chan amp.
fiberglass box is not needed for our cars with most subs. specially the 10w3. it will fit most mdf boxes. if you go to the c5 faq you'll see links on one off corvette specific parts. choose the box that fits your needs. plan on spending ~200 for the box
As Scott mentioned you can just turn your rear speakers off to get an idea, but it is not a very accurate one as the stock blose system is pretty bad in the front stage. Even I kept the rear speakers on when I was stock, and those here who know me know I NEVER do rears heh.
Look into the JL seperates or even their 3 way system from their upper end line and see how you like the sound. Other brands to try are DLS Iridium/Nobelium, Dynaudio, Focal, and from what some friends have told me the Steal of the Century is for the Pioneer PRS components. Ebay brand new right now for $200 and are AWESOME. This is coming from competition level audio friends who have heard 100's of cars. I have heard they are so good I might just grab a set to have for my next "basic" install for a DD.
As for the 4 channel bi-amping option you can go that way to give the car more presence in the midrange as it does not take too much power to run tweets and make them loud, however most crossovers are not set up to do it which means you would have to rely on the amp crossover to highpass or ideally bandpass the midrange outside of the passive crossover provided with the components.
Side note: I am also not a very big fan of JL, but if that is what you like the sound of its all good. Generally reliable.
G'luck
Fej
As far as the box goes....while you dont necessarily need more airspace for most speakers...a fiberglass box will be lighter...and when you just get one with a fiberglass bottom...and an MDF top...you wont be spending any more than 200 anyways. What it will give you though...is a tiny bit more clearance for your magnet...which could allow you to flush the speaker further in....to make it more stealthy.
Thanks for the feedback, guys. I'm really trying to do my homework and get this right the first time...
Find a DLS retailer, listen to the JL components, find the Pioneer's I mentioned, or if you want to get crazy check out diymobileaudio.com. Research it and put together your own 2 or 3 way component system. You can put together one hell of a 2 way for $250 there that will outperform anything you could pick up pre packaged for the same price. Only issue with that is either having to pick up a set of passive crossovers, or make your amp choices based upon the need to have crossovers built in that allow you to handle your frequency adjustments (or a HU with a built in crossover, used in conjunction with the amps if need be).
Infinity perfect 6.1 is nice as well, or try and find a set of the ED's to listen to.
Audison amps are highly regarded, good quality watts, good reliability, good resale value for the most part.
Fej
Theory goes that - over time, the harshness of the tweeters destroyed the corresponding fibers in their ears, so they can no longer hear it.
