Sponsored by: Innova
C5 CD changer problems
Old Dec 7, 2006 | 03:06 PM
JetJazz's Avatar
JetJazz
Default C5 CD changer problems
Hi Audio pros!
The stock 12 disc changer in my 2000 C5 stops working occasionally. I can hear it cycling then I get an "err" message. I slide the door open but the magazine does not eject. It will cycle three times then quit. The odd thing is: if I take out the six screws that hold the unit to the bracket and pull the unit out it will start working!!?? Weird.
Any ideas? Also, I noticed a reset button on the front. What is that for exactly? I pressed it and nothing happened.
Thanks for the help!
Old Dec 14, 2006 | 04:07 AM
EHS's Avatar
EHS
I'm going to bump this, because I have the same problem. Haven't tried the six screws solution.
Any advice on where to get a decent repair? Or replacement? I want to stay factory stock.
Thanks.
Old Dec 14, 2006 | 11:04 AM
JetJazz's Avatar
JetJazz
Thanks.
I'm puzzled by that fact that everytime I got to loosing the screws on the bracket this thing starts working!
I'm thinking about just making the change to mP3 instead or replacing mine.
The stock replacement is around $500 in the catalogs. I have seen them on eBay.
Jerry
Old Dec 14, 2006 | 11:52 AM
EHS's Avatar
EHS
Jerry -- I looked around at new/used -- don't want to spend $500 for a new, and don't trust the EBay used.
I also found out that the Bose head unit is pretty fussy about what you can hook up to it -- and there aren't any other Pioneers out there.
Old Dec 18, 2006 | 08:12 AM
markcz's Avatar
markcz
This may or may not be your problem.....
If the changer gets bounced around too much there is a pin (tab A) that can come out of it's proper position (slot B). Check out the pic below. You'll have to take all of the panels off of the changer to get at it, but if it ain't working now, how much harm can you do.
Old Dec 20, 2006 | 12:44 PM
MEXAKNPWR's Avatar
MEXAKNPWR
will a pioneer 12 disk changer work in the place of say what used to have a ac/delco 12 disk cd changer?
To C5 CD changer problems
