Sponsored by: Innova
New System Took A Dump - Help Please
Old Dec 12, 2006 | 12:02 AM
A.Fry's Avatar
A.Fry
Default New System Took A Dump - Help Please
i added a pac-oem, an amp, and sub. hooked up worked like a dream. took extra time ran everything clean and a sweet addition. i then added an xm terk and took the same special care hooked it up last night and another great add on. it was all working sweet and i shut her down and called it a night. tonight i was going to put the interior back and take her for a spin. i noticed that the xm didnt sound as nice as the head unit, a little bit of an echo sound, but i was able to live with it. i turned the head back over to fm and then i realized no base. the power light wasnt on at the amp. i checked the remote wire with a test light and it has fire. i then realized that i lost all base even in the stock amps WTF. i had to cut the cor-har 3 plug and soldier it in, i spliced the green to #15 on the back radio plug and i tied the ground and power to the acc plug in the pass. footwell. top left corner beside the comp. please guys help me get my baby back together again. thanks
Old Dec 12, 2006 | 12:13 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ok im thinkin maybe something is wrong with the PACAOEM1.
Your post was partially unclear for me I understand your amp isnt turning on, now is there or is there not power on the remote wire.
I believe the stock bose has a fuse somewhere it could be this
Old Dec 12, 2006 | 12:41 AM
A.Fry's Avatar
A.Fry
yeah the remote wire has power. but the power light on the amp is not coming on, and to top it off the bose amps arent working either
Old Dec 12, 2006 | 01:12 AM
pentavolvo's Avatar
pentavolvo
are u getting 12 volts to the amp on the lead from the battery, and is the remote giving 12 volts or something less
Old Dec 12, 2006 | 01:16 AM
A.Fry's Avatar
A.Fry
i will run out and check
Old Dec 12, 2006 | 01:32 AM
A.Fry's Avatar
A.Fry
hey pentavolvo, i dont know how ive got so stupid. i put a meter on the amp and the batt. power read 9.98 volts and the remote read 8,98 volts. battery is all the sudden dead. charger on now. i posted a thread lat night about the terk wireing. the power lead had a yellow and a red. i ran the red to the power acc. plug that is in the pass. footwell area. i hooked red to the orange full time power wire and the yellow to the yellow acc. wire that only powers with the key on. i am wondering if the terk may have drained the battery
Old Dec 12, 2006 | 02:09 AM
A.Fry's Avatar
A.Fry
bump
Old Dec 12, 2006 | 09:14 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
An XM receiver hooked to an always hot line will definitely kill your battery. Either change the power to an ignition source or maybe look to see if the Terk has an auto-off option. I know the SkyFi's have an option to automatically power down after X number of minutes to prevent an oops like this.
Old Dec 12, 2006 | 07:25 PM
A.Fry's Avatar
A.Fry
thanks, i was driving down the highway in my daily driver today and it hit me that the yellow wire is the memory wire and i have them crossed. thank you for the reply. i was at a total loss last night and realized today that i just had a brain fart
Old Dec 12, 2006 | 08:13 PM
pentavolvo's Avatar
pentavolvo
happens to all of us im sure you will be good to go once you get it wired up right
Old Dec 12, 2006 | 08:49 PM
scott_fx's Avatar
scott_fx
if you have any more electrical gremlins in your car (reduce power mode for example) don't fret, it's probably due to your battery and you may have to buy a new one. (speaking from experience)
Old Dec 13, 2006 | 01:32 AM
A.Fry's Avatar
A.Fry
thats all it was, everything is up and running again. got the carpet and console back in. just need the seat and fuse box cover put back on and i can clean her up and bust the road wide open again. thank everybody. anthony
To New System Took A Dump - Help Please
