Sponsored by: Innova
amp getting too hot?
Old Dec 15, 2006 | 10:35 PM
A.Fry's Avatar
A.Fry
Default amp getting too hot?
i just finished an amp, a sub, an xm radio and a nav install and everything finally came together and sounding great. i took her to town tonight and the base signal shut off about 20 minuites in. the power indicator light was on, both the amp and amp volume **** . i turned the radio off for about 15 minuites and tried it again and it was back. i guess its getting too hot? i mounted it on the back wall, i put a piece of plywood behind the carpeted back pannel and screwed the amp through it. should i put spacers between the amp and carpet? wtf everytime i take a sigh of relief and start enjoying it it takes a crap. the amp is a fosgate 325.1, w/ a 10" fosgate P1 sub. what do you guys think? thanks Fry
Old Dec 15, 2006 | 10:53 PM
fej's Avatar
fej
Is the amp mounted on the plywood BEHIND the carpet or on top of the carpet? If it is behind you have to get it some air. If it is not behind please tell us how you have it wired (the subs) and what load the amp is seeing. You may be pushing the ohm load too low with your set up and causing it to over heat ... where is the gain at in a minimum (0%) through max (100%) measurement?
Fej
Old Dec 15, 2006 | 11:07 PM
A.Fry's Avatar
A.Fry
i will go out and get that info. how do i check the load the amp is getting?
Old Dec 15, 2006 | 11:35 PM
fej's Avatar
fej
What model sub are you running? Is it DVC (dual voice coil) or single? Is the amp bridged or run in "stereo" channels?
Old Dec 16, 2006 | 12:04 AM
A.Fry's Avatar
A.Fry
ok here's some info. the sub is a 4ohm svc, 150w rms, 300w peak. the amp is mounted on top of the carpet, the gain is set at about 50%, the freq is set at about 50%, the crossover is set to lp. the speaker wires are plugged in to channel A + and - does this sound right? i cant find the manual for the amp
Old Dec 16, 2006 | 02:05 AM
A.Fry's Avatar
A.Fry
anybody awake out there tonight that can tell me what might be wrong? thanks
Old Dec 16, 2006 | 02:31 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sounds like amp over heating and it sounds like you have it hooked up right... check that your groudn is tight. Also did the amp physically feel hot
Old Dec 16, 2006 | 11:49 AM
DPG's Avatar
DPG
St. Jude Donor '06
back wall meaning the trunk back wall. that should have plenty of air circulation back there. even behind the pass seat, my amp doesnt get hot. warm, but not to where it shuts itself off.
Old Dec 16, 2006 | 04:34 PM
VinceC5's Avatar
VinceC5
make sure you use at least 8 gauge wire for power and ground. You could be starving the amp. Also looks like the amp is not designed to be mounted like that (hot air trapped in the cooling fins). May want to mounted another way, or throw a 12 v fan on the side.
Old Dec 17, 2006 | 10:08 AM
fej's Avatar
fej
At what level on the HU do you listen to it? IE 1-35 volume numbers is 15 loud? 20? 30? I would start first with cutting the gain down to minimum and see if the amp continues to overheat. Looking some stuff up be back in a few.
Fej
Ok did some research. You should have the positive and negative wires routed to match in to the "A" channels on the amp. With a SVC sub it should see a 4 ohm load so no problem there. You need to lower the gain down to at least 25% if not lower. You also need to bring that crossover point down to at least midway between the 80hz and 160hz marks on your amp. I would personally say 100hz or lower for your crossover point. Most people start at about 80hz for the subs.
Old Dec 17, 2006 | 01:37 PM
A.Fry's Avatar
A.Fry
when you say bring the crossover point down, are you talking about the freq. ****? thanks for helping
Old Dec 17, 2006 | 03:42 PM
fej's Avatar
fej
yes freq **** = crossover point. Subs operate best in the 80hz and down range. In your case with some factory components still being used around 100hz should be fine.
Fej
Old Dec 17, 2006 | 07:42 PM
A.Fry's Avatar
A.Fry
thank you fej. i will be taking a little trip this week and will be in the seat for the majority of the time, will get to enjoy the new tunes. thanks for the advise again. anthony
To amp getting too hot?
