Sponsored by: Innova
stereo install question
Old Dec 16, 2006 | 09:05 AM
gator79's Avatar
gator79
Default stereo install question
I will be installing a fixed screen DVD in the dash of my '93. crutchfield list the depth of the radio chassis as 6 inches, most aftermarket radios I am finding are 6 5/16 to 6 1/2 deep. is there any extra room behind the radio to fit the extra 1/2 inch? what is behind the radio is it a A/C duct or some metal bracing. ducting could be easily modified.
Old Dec 16, 2006 | 11:52 AM
DPG's Avatar
DPG
St. Jude Donor '06
is there mounting depth specs in the c4 sticky? ive never read through it. maybe i should so i at least know if info is there or not anywhoo, ttt for you
Old Dec 16, 2006 | 12:41 PM
GKK's Avatar
GKK
There's a plastic panel that supports the stock radio which has to be cut out to get the added clearance for an aftermarket stereo. I used a hack saw blade with a plastic handle.
Just read the C4 Audio FAQ sticky which has a lot of great information.
To stereo install question
