Sponsored by: Innova
Engine noise - need help
Old Dec 24, 2006 | 01:09 PM
jjk2509's Avatar
jjk2509
Default Engine noise - need help
I have a C5 with an after market system. There is engine noise when in radio mode. The CD play is clean.
Does this sound like an antenna issue rather than a ground issue?
Thanks in advance for any help.
Old Dec 24, 2006 | 02:56 PM
OzzyC4's Avatar
OzzyC4
engine noise? are you refering to a whining noise or a static noise?
Old Dec 24, 2006 | 03:01 PM
jjk2509's Avatar
jjk2509
It is more of a static noise that increases with the rpm. Some channels are better than others.
Old Dec 24, 2006 | 06:59 PM
EatRice's Avatar
EatRice
You are positive it only happens with FM? If that is the case you need to check the antenna...how old is the radio?
Old Dec 24, 2006 | 07:50 PM
fej's Avatar
fej
Poor antenna connection? Something grounding out behind the radio at the antenna connection spot? Usually ground noise (alternator whine generally) happens whenever the unit is on.
Fej
Old Dec 25, 2006 | 11:41 AM
jjk2509's Avatar
jjk2509
I will check the antenna behind the head unit. When the engine is off I get some clear fm channels and some with static. I get very few am channels. When the car is running, I hear an additional ticking noise that goes faster with the rpm. The h/u is an Eclipse similar to the one in you picture.
Thanks for the info.
Old Dec 25, 2006 | 02:45 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Still could be a ground loop. I think the C5 has an antenna amplifier module which is tripped on when you switch to radio. The ground of the amp/head vs the ground of the FM amplifier being in separate places could be creating a ground loop. If that's the case the best solution would be to find the ground for the FM antenna and ground it to the same point as your amp/head.
Old Dec 25, 2006 | 04:36 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
which antenna do you have, fixed, power, built into glass etc
Old Dec 26, 2006 | 08:49 PM
jjk2509's Avatar
jjk2509
I have the antenna in the rear hatch glass. I also have tinted windows.
Old Dec 27, 2006 | 09:31 AM
JLTD's Avatar
JLTD
I am willing to bet that there is at least one Class D amplifier in your car based upon what you've posted. The switching power supply in these amplifiers can interfere with amplified antenna systems. It does not happen all the time, but if you're the lucky winner, you're choices are limited to:
Replace the Class D amp with an A/B design
Replace the amplified antenna with a standard mast.
If you want to do a quick test, remove the remote wire to the Class D amp (so it doesn't power-up) and have a listen to the radio. Your noise should go away. Plug that wire back in and the noise will come back.
It's not a manufacturer thing as much as it's the nature of the beast with Class D at this point.
I hope this helps and it applies so this rant was good for something!
Old Dec 29, 2006 | 08:44 AM
jjk2509's Avatar
jjk2509
Where do I find the class D amp?
Thanks for the help.
Old Dec 29, 2006 | 10:05 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
It would be one (or THE one) aftermarket amp so it wouldn't be hard to find in a Vette... not likely under a seat but maybe, behind a seat or in the back. He's talking about a big aftermarket amplifier, not a stock amp buried in the dash or footwell.
To Engine noise - need help
