Sponsored by: Innova
2 amps - one wire?
Old Dec 26, 2006 | 10:48 AM
A.Fry's Avatar
A.Fry
Default 2 amps - one wire?
hey guys. hope you all had a good one! i am attempting another sterio install, this one in the ol' ladys car. i want to run two amps mounted together. question is can i run both 12 volt power wires through a splitter off one batt. amp lead? thanks
Old Dec 26, 2006 | 12:00 PM
VinceC5's Avatar
VinceC5
it can be done. Remember, the more current the amplifiers draw, the thicker the power cable has to be. What kind/watts are the amplifiers?
Old Dec 26, 2006 | 12:49 PM
fej's Avatar
fej
Yep, also you would be better off using a distribution block to split the wiring up. One main power wire, 4 aug or bigger, to the distribution block and split (with fuses for each amp) into the 2 other amps with I would guess 8 aug wire. I have a small amp on 10 gauge wire myself without issue. Fuses are your friend however, can't really have too many but a main fuse within 12" of the battery followed by a fuse for each amp is highly recommended (located as near the amp itself as is feasable)
Fej
Old Dec 26, 2006 | 01:06 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Its 100% doable but you will need a distrobution block
Old Dec 26, 2006 | 03:25 PM
dc3plt's Avatar
dc3plt
I run 2 amps with one wire.
4 gauge into the dist. block from batt. and 2 4 gauge to the amps.
Ground - 2 4 gauge in from amps. and 1 4 gauge to ground.
Works perfectly.
Later
Old Dec 26, 2006 | 04:12 PM
-=Jeff=-'s Avatar
-=Jeff=-
Works perfectly.
Later
you go from a single 4ga to two 4ga?? or is it 4ga to two 8ga?
I doe the same with a distro block 4ga to two 8ga for both power and ground
Old Dec 26, 2006 | 04:30 PM
A.Fry's Avatar
A.Fry
Thanks Guys
To 2 amps - one wire?
