Sponsored by: Innova
New Battery
Old Dec 29, 2006 | 01:16 PM
D C's Avatar
D C
USMC (retired)
Default New Battery
Should one change the battery to an Optima Yellow top at the same time a new system is installed?
IVA-W200 w/bluetooth & xm
Focal 165KP
Focal 165CV1
JL stealthbox
JL 500/5
Old Dec 29, 2006 | 08:09 PM
bogus's Avatar
bogus
not needed. You aren't adding enough... Now, when you replace the battery, sure, but I don't see a need now.
Old Dec 29, 2006 | 11:47 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
he's right, plus when you switch out the battery, there's no reason to get the yellow top unless you intend to leave you stereo on full blast on for a while with the engine off. The yellow top is a deep cycle battery which is good for long power drains, but in the case of sound systems, the deep cycle battery takes longer to deliver instantanious surges of power for har sub hits. (this is the true purpose of the capacitor)
your 500W amp will probably draw around 40 amps at peak (somwhere aronud 20 amps most of the time) so your alternator and battery shouldn't have any problem powering it.
Old Dec 30, 2006 | 02:07 AM
D C's Avatar
D C
USMC (retired)
Thanks. I never knew that about the yellow top. How about the red top optima?
Old Dec 30, 2006 | 02:09 AM
DPG's Avatar
DPG
St. Jude Donor '06
your better off spending money on doing the big 3 upgrade than a battery. upgrading that will make your current battery last longer and not put as much strain on your charging system. I plan on doing it in mine this winter.
To New Battery
